Both are definitely options as I cannot seem to find this cable myself (was hoping for the easy way). I did pick up a molex crimping tool but I do have some questions as I haven't had much success, instead just destroying some pins as I'm a novice.
This is the crimping tool I bought:
https://www.amazon.com/gp/product/B089LW7MWT/ … 0?ie=UTF8&psc=1
And the pins (.093):
https://www.amazon.com/gp/product/B07V478FN8/ … 0?ie=UTF8&psc=1
I have a molex extractor tool for .062 and .093 pins:
https://www.amazon.com/Connector-Remover-Comp … s%2C178&sr=8-14
The standard 4-pin AMP connector we all are used to in this retro hobby, can someone confirm the following?
- Are the female connector versions (with the male pins) model 8981?
- Are the male connector versions (with the female pins) model Mate-n-Lok 1-480424-0
And for the pins:
- I understand there are .062 versions and .093 - which are used most commonly in these AMP connectors?
- Is there a model # for these pins?
The problem I am running into is the question of these little metal 'sides' that are left when you cut the connectors out. What do you do with these?
![skzpxX.jpg](https://imagizer.imageshack.com/v2/xq90/922/skzpxX.jpg)
For an older AT power supply, I was not able to fit the .093 pins inside of the amp connector. It seemed to get 'stuck' and I wasn't sure if it was due to the pin size or if it was the little metal pieces left over from cutting the pins from the 'chain' they were attached to.
- Will this crimping tool work for those JST PH4 (4-pin) connectors?
- Can someone point me in the right direction on the pins and connector to buy (and crimping tool if I need one different from what I have?)
![LihnlZ.jpg](http://imageshack.com/a/img538/6600/LihnlZ.jpg)
