First post, by Bancho
- Oldbie
Hi All,
I recently picked up a really nice Compaq 7792 DMT laptop. The issue with it is that the FDD doesn't read disks and it didn't come with the CD-ROM Drive. The original Win95 Install is still present on the machine, but its a mess. I can get into windows and access the partitions. The Laptop has a 5gig Hard disk with 3 Partitions. I can get stuff on to the laptop in the form of a PCMCIA - Compact Flash Adapter.
This is my current plan
1.Copy all the required drivers and Win95 Folder to one of the partitions via the Compact Flash Adapter.
2.Boot into the Command Prompt via F8
3.Format C: Partition - Don't restart
4.Xcopy the Win95 Folder to the C: partition
5.Start the Setup for Win 95
6.Install Drivers after setup has finished.
7.Happiness that it all goes according to plan
Can you see any pitfalls or anything that could catch me out in my plan? Is there anything is could do to have access to the laptop from boot if it all does pear shaped? The FDD is recognized but its a Citizen W1D unit and i think the belt has failed as it wont read the disks.
Any expert advice would be greatly appreciated
Thanks!
