First post, by dkjr
So I bought the cheapest AM486 DX5 133 from ebay, and it arrived... At first I thought what the heck is this, they sent the wrong chip!
But the markings really say am486dx5-133v16bhc , it is the embedded version 🤣
What can I do with this? I don't know if I can install this in a socket 3 motherboard.
    904.96 KiB
Reply 1 of 7, by debs3759
That is a genuine 5x86, but unfortunately no use to most people. They are often found on upgrade adapters.
Reply 2 of 7, by The Serpent Rider
You can make PCB adapter, similar to how embedded 386DX40 were made:
Reply 3 of 7, by megatron-uk
Yep, you would need to solder that to a custom QFP to PGA adapter and I've not seen one for that layout before. Were any 486 motherboards sold with soldered-on processors that were not PGA chips?
https://www.target-earth.net
Reply 4 of 7, by The Serpent Rider
Where any 486 motherboards sold with soldered-on processors that were not PGA chips?
486SX mostly.
Also Kingston upgrade module (5x86 with VRM) use embedded version.
Reply 6 of 7, by debs3759
megatron-uk wrote on 2021-02-18, 09:16:
I don't know any motherboards that had them soldered on, but there were a few adapters that used them.
