First post, by NewRisingSun
FixMPU is a software solution for the "hanging note bug" encountered when using the MPU-401 interface of Sound Blaster 16 cards bearing DSP versions greater then 4.05 and smaller than 4.16. Refer to this wiki article ("Type 1" only) for a more detailed description.
FixMPU acts as a launcher for the actual game. Instead of typing "DOOM" at the command line, type "FixMPU DOOM", followed by any command line parameters. The BLASTER= environment variable must be correct in the the A, I and P values. Only IRQs below 8. On two tested systems with affected Sound Blaster 16 cards, FixMPU successfully prevented the well-known high-pitched garbage notes from occurring. FixMPU does not attempt to correct any other hardware or software problem, such as slow-downs or missing MIDI messages as a result of games' short delay loops (hello LucasArts and Sierra).
Please refer to the included FIXMPU.TXT for technical details. Source code included. Comments welcome, but only to this thread, not via PM.
Reply 1 of 20, by darry
NewRisingSun wrote on 2020-10-31, 14:41:
This is very interesting and useful . Thank you very much for sharing .
Reply 3 of 20, by ViTi95
Wow this is just incredible! I'll try it for sure! Also thanks for sharing the source code, this will allow me to integrate this fix into FastDoom sound code 😁
https://www.youtube.com/@viti95
Reply 4 of 20, by Pierre32
Wow, look forward to testing this on my CT1740. Thanks for your work!
Reply 6 of 20, by EmpireOfScrap
This is quite amazing work. Thank you also for explaining the theory of operation and providing the source code in the archive.
I have tried this out with two cards yesterday and it worked fine out of the box! I will do more testing later, but reading on how it works, I assume it will work the same on all the cards.
Reply 7 of 20, by djurecka
NewRisingSun,
I created a Vogons account for one main reason - to say thank you! DOOM music now plays without the hanging notes. You rock! Creative CT4180 Vibra 16.
Reply 8 of 20, by Oetker
I don't understand how I haven't seen this thread before, what a great tool! The analysis is very interesting, I'd be curious to know how you discovered the mechanism behind the bug. And, do you have any idea what causes the Type 2 bug and it that could be fixed?
It's especially great that this tool works with protected mode games.
Reply 9 of 20, by Oetker
Also, the analysis of the slowdown Duke3D is very interesting, I assume you've looked into the source code? Is it a conflict between
MPU_SendMidi (tests if device is ready)
MIDI_Reset (disables interrupts)
BLASTER_ServiceInterrupt (waits for an interrupt from the digital audio part)
Looking at the code further it seems MIDI_Reset is called whenever a track is (re)started, so maybe that explains why the game will also hang during gameplay, not just at the 3DRealms logo. I guess it should be possible to fix the game's audio library?
Reply 10 of 20, by ViTi95
Duke3D uses the Apogee Sound System, the source code is fully available so it's possible to fix it. I'm using it for FastDoom (as DMX is closed source) compiling it instead of linking as a prebuilt library, maybe you can use it to fix that problem.
Reply 11 of 20, by muteKi
Simple, probably silly, question -- when you say "MPU-401" does that include wavetable headers?
Reply 12 of 20, by Gmlb256
muteKi wrote on 2022-06-06, 18:21:
Yes, it also usually includes the WaveBlaster header.
Reply 13 of 20, by mkarcher
On SB16-like cards (that's the only family of cards requiring FixMPU), the wavetable header and the gameport MIDI output share the same signal. So everything that influences MIDI output always applies to both. This is true for FixMPU, too. (SB16-like cards include the AWE32 and AWE64 cards, because those cards only differ in having an EMU8k synthesizer that is separate from the MIDI/DSP system that has the hanging note issue)
Reply 14 of 20, by villeneuve
I wonder how FixMPU does compare to SoftMPU. Two search engines I tried didn't give me any clue about that. Anybody here able to give me a hint?
Reply 15 of 20, by darry
villeneuve wrote on 2022-06-06, 22:44:
They are completely different things.
FixMPU addresses a bug in SB16, AWE32, SB32 MPU-401 implementation with certain DSP versions.
SoftMPU allows for intelligent mode MPU-401 emulation on any sound card with a UART mode only (so called "dumb") MPU-401 compatibility or with a an SB MIDI port or even through a serial port.
Reply 16 of 20, by villeneuve
Thanks very much for the explanation @darry. I'll put it into my notes to avoid personal confusion between the two projects in the future.
Reply 17 of 20, by muteKi
mkarcher wrote on 2022-06-06, 22:17:
Ah, thanks. I don't have any external MIDI modules but I do have a wavetable card (that sounds close enough to soundcanvas for me to quite enjoy playing, say, DOOM with it) so being sure this would fix it (which I suspected based on how it works) is good for me and my recently-acquired Vibra16S.
Reply 18 of 20, by EricDraven
darry wrote on 2020-10-31, 16:35:
Hi Darry
Sorry
I'm a new member but I can't find it Fixmpu to download Thank you
Reply 19 of 20, by darry
@EricDraven
You probably meant to ask your question to NewRisingSun , who opened this thread.
That being said, there used to be a file attached to the first post [1]. That link is now gone from the post and does not work either. I do not know if this intentional or a forum bug.
You can still get the file from the Internet Archive [2].
EDIT: I messaged admins about this.
[1]
download/file.php?id=95203
[2]
https://web.archive.org/web/20230430052022/ht … le.php?id=95203
