First post, by robertmo
When copying lots of files to a FAT32 formatted USB flash memory pnedrive stick you can arrange them from smallest to largest and start copying.
Once it starts to slow down you can just stop copying, create a folder inside and another one inside the new folder and continue copying to the deepest folder till it slows down again. Now you can create folders again and copy again. And repeat until all is done.
I read that on Linux and Mac OS you don't have to use such tricks when copying to a FAT32 pendrive.
Reply 1 of 7, by Jo22
Hi! Thank's for the tip! 😀 👍
Reply 3 of 7, by robertmo
well.. 0.04 MiB/s (0.37 files/s)
If there was a program that used my trick.
For example copy to a new folder every 5 seconds and than move them to one folder at the end.
Copying would be almost instant.
Reply 4 of 7, by Miphee
Put the files in a zip first so you only have to copy 1 large file instead of many small ones.
Reply 5 of 7, by robertmo
that's not really a solution if you have a bootable pendrive with working apps on it 😀
Reply 7 of 7, by Ozzuneoj
An alternative solution would be to get a cheap but decent SSD and use a USB adapter. It's incredible how much faster a real SSD is compared to a flash drive or hard drive, even over USB. A lot of that speed improvement comes from the transfer of small files.
A pile of used low capacity SSDs can often be had very cheaply. If you go with mSATA or m.2 drives you can get really small adapters that are closer to flash drive size.
