Reply 40 of 48, by weedeewee
B24Fox wrote on 2021-04-28, 17:57:weedeewee wrote on 2021-04-28, 16:55:on a side note... I meant brooktree (from the Bt chipsets) which got bought by Rockwell, which changed its name to Conexant, […]
on a side note...
which got bought by synaptics, not broadcomI only asked to make sure we were both referring to the same chip : ) But wow!! 😳
I just added it, because it was bugging me that I said broadcom, while I meant Brooktree. So I had to look it up for my own sanity 😁
Oh and for the composite out, you'll just need a cinch connector. that would allow you to hook it up to a tv with scart or composite in and you can verify that it works. that is.. if you have such a tv...
Do not ask Why !
