Reply 39240 of 59393, by AngryByDefault
- Member
PC@LIVE wrote on 2021-05-29, 19:50:[...] I would have LAN cards but they don't have the RJ connector, they only have the one for RG coaxial cable, I don't think there is a way to adapt it (maybe through HUB?)
Yes! there are hubs with 8 RJ45 lan ports and "uplink" to a coaxial network. I have used them in the past and was a great solution (on a TCP/IP network).
Mind you, I have a vague idea that there were some other network devices that were very smiliar but were meant for a different porpouse.
HTH
