Movies for a 486 computer ?
Reply 20 of 29, by Joakim
Yeah you probably need some sweet hardware acceleration for this. I remember that showcase video for pentium mmx, a technology which somewhat opened up for software rendering I guess? Think it was an eye on the video moving in high resolution, that you showed off to all your friends with lesser computers.
Reply 21 of 29, by BitWrangler
Yah the gfx chip builtins didn't do 100% of the heavy lifting, think it was with an S3 Virge card that my buddy's DX2 needed to be run at 80 to smooth it out for VCD playback. At DX2-66 it almost managed, but would stutter every 7 or 8 seconds. I think he had an AMD, not sure, anyway, possible that an intel DX-2-66 on a good board, well tuned would just make it.
Reply 22 of 29, by Nexxen
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 23 of 29, by Intel486dx33
Here I am playing an MovieCD on my 486dx4-100 at 800x600 full screen.
It play okay I think.Audio sounds good too.
My computer specs
Intel 486dx4-100 overdrive CPU ( same as standard 486dx4-100 CPU ).
16mb FPM ram, 60ns
256kb cache -20ns
Cirrus logic 5429 VLB video card set at 800x600 256-colors.
512mb IDE harddrive
VLB controller DTC dual channel
8x Sony IDE CDROM drive.
Sound Blaster Pro 2.0
Just burn to CD the player is included in CD.
Link:
https://archive.org/details/GATEMINDSEYE-MovieCD
Reply 24 of 29, by Azarien
Technically, every movie can be re-encoded to MPEG-1 or such so you can watch it on a 486 just to make a point, but you'd need to do the re-encoding on a modern computer anyways - so it would take half an hour instead of a month...
Reply 25 of 29, by BitWrangler
When you're playing with 16GB CF cards and large hdd bioses, you can run it through your quad core and make a movie that you can watch in EGA on your 286.
Reply 26 of 29, by lolo799
Intel486dx33 wrote on 2021-06-03, 13:57:
Here I am playing an MovieCD on my 486dx4-100 at 800x600 full screen. It play okay I think.Audio sounds good too. […]
My computer specs
16mb FPM ram, 60ns
256kb cache -20ns
512mb IDE harddrive
What enlargement style were you using, if any?
Reply 27 of 29, by Intel486dx33
lolo799 wrote on 2021-06-03, 15:02:
My computer specs
16mb FPM ram, 60ns
256kb cache -20ns
512mb IDE harddrive
None. I just select “Full Screen” button.
Reply 28 of 29, by lolo799
Is there one selected by default in the options menu, or in file/properties?
Reply 29 of 29, by Intel486dx33
I am just using the default settings.
“Fast as possible”
