Why not a Intel Desktop Board DG43NB ?
I have this board and installed XP, Windows 7 e 10 whit no problem.
CPU SUPPORT https://www.cpu-upgrade.com/mb-Intel/DG43NB.html
Feature Summary
Form Factor ATX (294.64 millimeters [11.60 inches] x 243.84 millimeters
[9.60 inches])
Processor Support for an Intel ® processor in the LGA775 package
Main Memory • Two 240-pin, DDR2 1.8 V SDRAM Dual Inline Memory Module
(DIMM) sockets
• 800/667 MHz single or dual channel DDR2 SDRAM interface
• Support for up to 4 GB of system memory
Chipset Intel ® G43 Express Chipset consisting of:
• Intel G43 Express Chipset Graphics and Memory Controller Hub
(GMCH)
• Intel ® 82801JB I/O Controller Hub (ICH10)
Graphics • Intel G43 Express Chipset with Intel ® Graphics Media Accelerator
X4500 (Intel ® GMA X4500)
• One PCI Express* 2.0 x16 connector supporting PCI Express
graphics add-in cards
• Support for dual independent displays via the DVI-D and VGA ports
Audio
Onboard subsystem, featuring:
• Independent 6-channel (5.1) audio streams
• 2-channel stereo audio streams via an onboard header
• Intel ® High Definition Audio (Intel ® HD Audio) interface
• RealTek* ALC888VC audio codec
• Onboard 3-pin S/PDIF output connector
Expansion
Capabilities • One PCI Express 2.0 x16 connector
• Three PCI Express 1.1 x1 connectors
• Three PCI* connectors
Legacy I/O Support Legacy I/O Controller that provides:
• PS/2* keyboard and mouse ports
• One serial port via an onboard header
Peripheral
Interfaces
• Up to 12 USB 2.0 ports:
― Six ports routed to the back panel
― Six ports routed to three USB headers
• Up to two IEEE 1394a ports:
― One port routed to the back panel
― One port routed to an onboard IEEE 1394a header
• Six Serial ATA (SATA) channels (3.0 Gb/s) via ICH10
• One IDE interface with ATA-66/100 support (two devices)
BIOS •
Intel ® Platform Innovation Framework for EFI
32 Mbit symmetrical flash memory device
Support for SMBIOS
Intel ® Rapid BIOS Boot
Intel ® Express BIOS Update
Power Management •
Support for Advanced Configuration and Power Interface (ACPI)
Suspend to RAM (STR)
Wake on USB, PCI, PCI Express, PS/2, LAN, and front panel
ENERGY STAR* capable
Hardware
Management Hardware monitor with:
• Four fan sensing inputs used to monitor fan activity
• Intel ® Quiet System Technology (Intel ® QST) fan speed control
• Voltage sensing to detect out of range values
LAN Support Intel ® 82567LV Gigabit (10/100/1000 Mb/s) Ethernet LAN controller
Operating System Support •
Windows Vista* Ultimate
Windows Vista Enterprise
Windows Vista Business
Windows Vista Home Premium
Windows Vista Home Basic
Windows Vista Ultimate 64-bit edition
Windows Vista Enterprise 64-bit edition
Windows Vista Business 64-bit edition
Windows Vista Home Premium 64-bit edition
Windows Vista Home Basic 64-bit edition
Windows* XP Media Center Edition 2005
Windows XP Professional
Windows XP Professional x64 Edition
Windows XP Home
