First post, by dreamblaster
preparing for upcoming McCake,
i redesigned CHiLL interface PCB into CHiLL II.
It now has midi activity led, and on board high current supply for 5V, +12V and -12V
At this moment, this is for experimental purposes.
Thanks for your support !
Reply 1 of 14, by dreamblaster
short doom E1M1 demo with XR385 : https://youtu.be/eNUihGkwNDo
Reply 2 of 14, by dreamblaster
XL enclosure under development,
XR385 fits nicely in it.
Enclosure still needs minor change : (make more room for top of DIN connector)
Reply 4 of 14, by dionb
Nice!
Is that ChillXL enclosure also nearing completion? I have two daughterboards that stick waaaay out from the regular Chill 😉
Reply 5 of 14, by dreamblaster
dionb wrote on 2021-02-01, 00:28:
Yes, next iteration is being sent to me from the 3d print company. expected to try this week.
Reply 6 of 14, by dreamblaster
next iteration of CHiLL XL enclosure
(still not final)
Reply 7 of 14, by darry
dreamblaster wrote on 2021-02-02, 17:08:
(still not final)
That looks great! I am considering getting one or two (Chill II and enclosure) for my Wave Blaster II (CT1910) and Monster MIDI 4MB .
I have the previous Chill model for my X2 and love it .
Since I am in North America (the optional PSU is only available in Euro version), I use it with a Roland PSB-120 using a barrel adapter like this one https://www.amazon.ca/gp/product/B01N812NKL/ and an in-line power switch like this one https://www.amazon.ca/gp/product/B01CWNMB86/ . I feel safer knowing that I am using a well regarded PSU rather than Ebay's "firestarter of the month" and appreciate the ability to turn the unit off when not in use .
I am mentioning these as suggestions for possible add-on items that you might want to consider selling as well (EDIT : assuming that I am not the only one to find them useful) .
Thanks again for the great work and fantastic products !
Cheers!
Reply 8 of 14, by dionb
(still not final)
Ooh yes, that looks perfect. Will probably be ordering two when they're ready 😀
Reply 9 of 14, by dreamblaster
minor update :
CHiLL III
compared to CHiLL II :
- +12V/-12V indicator LED
- optional power outlet for 'floppy power cable' for McCake
- minor changes to switching circuit, to avoid not-available components
Reply 10 of 14, by dreamblaster
Produced a first small batch of these CHiLL III, it replaces CHiLL II
https://www.serdashop.com/CHiLL3
Reply 11 of 14, by mihai
Does it work with a chillbox enclosure?
Reply 12 of 14, by dreamblaster
mihai wrote on 2021-06-13, 12:14:
Yes , same dimensions
Reply 13 of 14, by dreamblaster
I now have new CHiLL III board, and will make solder kits of it, including the optional McCake power output.
I will start a separate thread for it, as it has grown a bit different from CHiLLL II
Reply 14 of 14, by dreamblaster
Original CHiLL and CHiLL II are now retired and replaced by CHiLL III.
I added the original CHiLL board information to the museum page : https://www.serdashop.com/Museum
I am also making a new linear regulator version of the CHiLL board, called "CHiLLin", which is a more direct descendant of the original CHiLL.
