Reply 100 of 105, by IIGS_User
- Oldbie
wrote:I cant run config.exe in native mode, Windows 7 64bit here.
Do you do not run this within DOSBox?
Klimawandel.
Klimawandel.
wrote:wrote:I cant run config.exe in native mode, Windows 7 64bit here.
config.exe from fifa doesn't run from DosBox either. I read this somewhere in the forum too...
But config.exe only generates a fifa.cfg file (I had that file from a old 486 backup). I tried modifying the file in the notepad++ (changing and running), but no luck.
did you try cputype=386_prefetch ?
Config works in SVN and will most likely work in the upcoming DOSBox release.
Try changing FIFA.CFG to this:
SFX 14,0220h,07,01,-1MUSIC 14,0220h,07,01,-1
That should work with the default SB16 config in DOSBox.
EDIT: You can also try this if your system supports GM music:
SFX 14,0220h,07,01,-1MUSIC 02,0330h,02,-1,-1
386_prefetch fixes the issue.
