Reply 100 of 354, by ruthan
- Oldbie
wrote:Run SETUPDS then load DSDMA, apparently.
Problem is that i dont know why in some drivers packages - for example in Vogons DOS packages is not DSDMA.exe, i didn overlook something, i just copied files i didnt used install.. but i have found DSDNA in AOPEN driver package.
Results:
On Z97 computer freezes in every memory manager settings, on X58 (HP O.E.M MB) its running well, so settings is good, thanks for help.. Z97 seems to be dead end.
Only strange this, which i had to make it working on X58, with EMS, was this strange line which i found someone on internet, i needed it too to make Creative SB emu driver load for Audigy. Im using HimemX, i dunno if it matters.
DEVICE=C:\WINDOWS\EMM386.EXE 16384 D=64 FRAME=E000 /I=B000-B7FF RAMinstead of classical: DEVICE=C:\WINDOWS\emm386.exe RAM
Its working in both and XMS boot branches, by which i means this:
EMS- DEVICE=C:\WINDOWS\HIMEMX.EXE /MAX=65424 /METHOD:FAST /VERBOSE ; DEVICE=C:\WINDOWS\EMM386.EXE 16384 D=64 FRAME=E000 /I=B000-B7FF RAMXMS - DEVICE=C:\WINDOWS\HIMEMX.EXE /MAX=65424 /METHOD:FAST /VERBOSE ; DEVICE=C:\WINDOWS\EMM386.EXE noems
Its not working in Protection mod, because DSDMA needs EMS running..
By protection mod author of my config means - DEVICE=C:\WINDOWS\HIMEMX.EXE /MAX=65424 /METHOD:FAST /VERBOSE
no EMS line
Could someone confirm intel H/Z 6x/7x/8x compabitility with Yamaha 7x soundcards? They should have native PCI implementation unlike Z97.
Thanks for help.
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
