Reply 100 of 138, by Hummtaro
- Newbie
duboisea wrote on 2022-10-22, 03:55:Do you think it would be possible to fit the ESFM Soundfont into 64M?
I would not say it's impossible to shrink this to 64M but it would need a lot of time and skills probably nobody will spend on it.
But there will be a new DreamBlaster with way more Flash memory release this year:
DreamBlaster X16 Prototypes/Development thread
rakarek wrote on 2022-10-26, 21:15:Hi. Below is a link for Gravis Ultrasound Classic GM bank converted by me to sf2 format, in 1999. I hope that i will see your opinion regarding to this bank. I hope that someone can convert this bank to dreamblaster format.
I could try it but how is it different from the other Gravis Ultrasound Bank i've already converted?
RetroGamer4Ever wrote on 2023-01-01, 01:24:Chicken Systems "Translator" sample conversion software works with a variety of sample formats and also apparently works with Dream sample banks, if you get the High-Tech Edition. The support information is spotty on the software's specifics, because the company has shut down their forum and such, but they still sell the software.
You still need Dream's Sound Development Kit to compile a bank out of the files ChickenSys Translator outputs and their format support is very poor.. As far i've tested SF2 and DLS are only partially supported and Dreams format even less.. So the conversion using Translator is almost useless.. Otherwise i would have way more banks available here.. 😉
X570|R5 5600X|32G|Rx6800
