Voodoo 3 3000 AGP under performing?
Reply 100 of 113, by bloodem
zuldan wrote on 2025-04-04, 09:44:
No performance issues with a Banshee (PCI) on MVP3. What’s strange is my Voodoo 3 (AGP) was getting a score of 2400 on this same motherboard? I had a refresh install of Win98 SE with the chipset drivers installed (including the AGP driver).
This further proves that it's NOT the same issue as the one described in this thread which affects certain Ali Aladdin V chipset revisions, because those have the same (low) performance with either an AGP or a PCI Voodoo card.
My guess is that the issues with MVP3 can probably be mitigated by playing with the chipset driver versions & co.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 101 of 113, by mwdmeyer
I agree. The Aladdin V issues seem to be a very specific hardware issue.
I'd suggest opening a new thread to discuss your issue with the MVP3 motherboard.
I never did test the Rev 1.1 gigabyte board. Will need to try again.
Reply 102 of 113, by PcBytes
Test results.
- DFI K6BV3+/66 Rev B2 - MVP3 + 596B
- 128MB RAM
- K6-2 500MHz (standard, no plus or anything else)
- 8 GB WD Caviar 28400
- VIA 4in1 4.35
Cards tested:
- Voodoo 3 2000 PCI
file.php?mode=view&id=216253
- Voodoo 3 3000 AGP
file.php?mode=view&id=216254
Reply 103 of 113, by bloodem
PcBytes wrote on 2025-04-04, 19:42:
Test results. […]
Test results.
- 128MB RAM
- VIA 4in1 4.35
Cards tested:
- Voodoo 3 2000 PCI
- Voodoo 3 3000 AGP
Yeah, those scores are abysmal. But they are NOT related to the 596B southbridge, something else is going on here.
Then again, you are using a regular K6-2 CPU, I haven't tested one of these in a very long time, so not sure what the expected performance should be in 3DMark99. Do you have a K6-2/3+ to test as well?
Reply 104 of 113, by PcBytes
I have a K6-2+ at the same speed I could test, currently sitting in a GA-5AX rev 4.1.
Reply 105 of 113, by PcBytes
K6-II+ 500, same cards tested.
V3 2000 PCI:
The attachment 20250404_232530.jpg is no longer available
V3 3000, AGP:
The attachment 20250404_231634.jpg is no longer available
Reply 106 of 113, by PcBytes
And another set of tests. This time, FIC PA-2013 (with older 586 southbridge) and K6-II+ , otherwise same cards.
V3 2k PCI
The attachment 20250404_235347.jpg is no longer available
V3 3k AGP
The attachment 20250405_000410.jpg is no longer available
I'l test a 693/596B Katmai board just to rule out VIA being VIA.
Reply 107 of 113, by PcBytes
This is where it gets fishy. Below results are from a 500MHz Katmai, VIA693+596B based MSI 6156VA. I'm pretty sure these are NOT the scores a Pentium 3 should be getting.
Same settings were applied to all three mainboards tested:
- no other cards inserted
- USB, serial, LPT disabled
- RAM set to CL2
V3 2k PCI
The attachment 20250405_003809.jpg is no longer available
V3 3k AGP
The attachment 20250405_002757.jpg is no longer available
Reply 108 of 113, by bloodem
I would say this is in line with what I would expect from VIA, compared to a 440BX board.
Here's a Pentium 3 Katmai 600 MHz benchmark video I created a few years ago (using a 440BX board) and a GeForce 2 Ti @ Ultra clockspeeds: https://youtu.be/2UkFnM_rYqE?si=BLbWf3SCaCtighJt
~5600 points in 3DMark99 with a much faster video card, much faster chipset and a faster CPU... so, I think your 3DMark99 score is normal for an Apollo Pro 133 board with a Katmai 500 and a Voodoo 3.
Reply 109 of 113, by PcBytes
I'm still having some doubts. There's something wrong that the P3 500 (which is 100MHz less than yours) scores on par with the K6-II+ @ FIC PA-2013. I would've expected both cards to at least score 4100 for AGP and 3500-3700 for PCI, given I've tried to keep the same settings for all of them:
- disabled USB, Serial, Parallel ports
- disabled onboard ES1373 for the 6156VA
- used VIA 4.35 drivers, as most recommend
Reply 110 of 113, by bloodem
PcBytes wrote on 2025-04-05, 15:24:
I'm still having some doubts. There's something wrong that the P3 500 (which is 100MHz less than yours) scores on par with the K6-II+ @ FIC PA-2013. I would've expected both cards to at least score 4100 for AGP and 3500-3700 for PCI.
3DMark99 is very well optimized for AMD's 3DNow! instructions, so those high scores you will see in that benchmark will very rarely translate into real world performance.
Just look at these two:
https://youtu.be/2UkFnM_rYqE?t=214
https://youtu.be/jrV6vPGR3Yc?t=410
In the first video, it's the Pentium 3 Katmai 600 on a 440BX board with the GeForce 2 Ti, scoring 5619 3DMarks / 9139 CPU marks
In the second video it's the K6-3+ @ 633 MHz, on an Ali Aladdin V board (Asus P5A), with the same GeForce 2 Ti card. And, surprisingly, it managed to score 5420 3D marks / 9276 CPU marks.
Is the K6-3+ comparable to the Katmai 600 (especially when the latter is running on a 440BX board)? Of course not, not even close, in actual games the Katmai 600/440BX combo will be anywhere between 30% to 50% faster, with few exceptions.
Reply 111 of 113, by byte_76
Chaintech 5AGM2
K6-2+ 550
128MB
Voodoo 3 3000 AGP 16MB
Win98 SE
The via 4-in-1 drivers are not installed because Windows won’t complete boot when they’re installed.
These results are massively better than my GA-5AA rev 1.1.
Reply 112 of 113, by byte_76
Asus P5A-B Rev. 1.05 with resistor mod
AMD K6-2+ 550MHz
128MB PC100
Windows 98SE
DX7 and
AGP GART 2.13
Reply 113 of 113, by jpvalverde85
Hi, im new at Vogons but old gamer. I recently was able to assemble a pretty cool old rig
1GHz P3 Slot1 with 133 FSB
Asus P3V4X
2x 256MB PC133 Spectek
Voodoo3 3000 AGP (also for testing i have a 2000 AGP and a Matrox G550 PCI)
SB Live! 5.1 SB0100
I installed Win2000 Pro SP4, Via 4in 1, Regular Creative drivers, and Amigasport XP drivers. I'm absolutely and positively happy with the 3d performance of the rig, but im very puzzled with the 2d performance behavior, i just discovered when playing Plants vs Zombies with my children that in windowed mode we can enable hardware acceleration and the performance is excellent, no stutter at all (but the res of windowed is the same as full screen, and cant move the window), but in fullscreen mode something happens that hardware acceleration turns off, cant enable it back, and performance is atrocious, when the screen fills with sprites it goes deep into single digit fps. Any ideas?
