Reply 100 of 598, by florian3
rasteri wrote on 2023-01-07, 19:01:I'm sure there must be connectors somewhere that fit it.
I haven't found one so far. According to the spec sheet linked in the kicad footprint it should be a Powerdynamics PDI-9R-5. But I haven't found a place that sells it. The only part I found that somewhat matches is EDAC 624-009-361-033, mouser has a few. But only the signal pins should fit, not the holes for the boardlock. It's also $5, more common ones are around $1.
I tried to replace the footprint in the kidcad project here. Just tried to squeeze it in by moving a few capacitors and traces.
