Reply 100 of 126, by rasz_pl
Ok, this is beyond stupid. going as simple as possible, only outputting first two bytes:
https://github.com/raszpl/FIC-486-GAC-2-Cache-Module for AT&T Globalyst
https://github.com/raszpl/386RC-16 memory board
https://github.com/raszpl/440BX Reference Design adapted to Kicad
https://github.com/raszpl/Zenith_ZBIOS MFM-300 Monitor
Reply 101 of 126, by feipoa
POST card shows:
66|F0
Reply 102 of 126, by rasz_pl
YaY progress!
F0 was my marker to see if its executing at all. Still no clue why does it hang after one byte 😐
66 should be AA.
lets try 2 bytes at a time
Should be AA 55, and on second one 5A A5.
Reply 103 of 126, by feipoa
POST card for "one and two" shows:
66|04
POST card for "three and four" shows:
d0|F7
Reply 104 of 126, by rasz_pl
what the actual
66 04 d0 F7
AA 55 5A A5
~50% bits in common, might as well be random 🙁
one more try with delay loops, in theory there should be ~1 second delay two times between changing numbers
Reply 105 of 126, by feipoa
POST card shows F0|12
Reply 106 of 126, by rasz_pl
looks like your POST doesnt like it when I output two times in a row without sufficient delay
lets try something I saw in another bios, dummy output "out 0E1h, AX" to a non existent port as a delay
Reply 107 of 126, by feipoa
POST card shows:
0F|12 initially
and
F0|0F a few seconds later
Reply 108 of 126, by rasz_pl
woohoo, I finally managed to tame your post card 😀 at least partially, there should be '34' there after ~2x longer delay tho
fingers crossed this one cycles properly, im still not sure how long the delay is on real hardware, so give it a minute if it doesnt cycle
EDIT: wait, we are executing from ROM, there is no ROM in RAM, there is no RAM, and ROM is set as uncacheable, and Im not sure about L1 cache (should be enabled?) you said "few seconds" and this was barely 65K cycles delay. I think I miscalculated badly 😀 irl hardware is a LOT slower, 86box doesnt emulate slowness of eprom, making another one brb
edit2: done, ~20000 cycles delay, if its executing from bios with no caching thats gonna be .. hmm still too fast? at least this time you should see movement
Reply 109 of 126, by feipoa
I have had to temporarily remove the motherboard from the testbed. I will pick this up again after SXL2 testing is complete.
Reply 111 of 126, by feipoa
With the SXL2 testing wrapping up, I've made space for the Asus PCI/I-P54TP4 motherboard again. Getting pipelined burst SRAM working on this board isn't looking promising.
Upon running t15i0302 delay 5000.7z, I see a repeating series of numbers:
83 | 02
10 | FF
E8 | 72
00 | 69
-repeats indefinitely-
Reply 112 of 126, by rasz_pl
Now I need to remember what was my code doing in the first place 😀 but repeating same string of numbers is a good sign. How fast are they changing?
edit: found it, this is the code being executed
_F000:E22A				   mov	   dx, 80h
_F000:E22D mov ax, 1000h
_F000:E230 mov es, ax
setup
_F000:E232
_F000:E232 loc_FE232:
_F000:E232
_F000:E232 xor di, di
_F000:E234 loop loc_FE232
quick loop just in case
_F000:E236				   mov	   ax, 0F00Fh
_F000:E239 mov es:[di], ax
_F000:E23C wbinvd
write F00F to beginning of test area and flushing cache, after that cache is empty and first two bytes of ram should contain F00F
_F000:E23E loc_FE23E:
_F000:E23E mov ax, es:[di]
_F000:E241 out dx, al
_F000:E242 out 0E1h, ax
_F000:E244 xchg ah, al
_F000:E246 out dx, al
read back two bytes and push to diag card, this should read F00F on the card on first loop
_F000:E247				   out	   0E1h, ax
_F000:E249 mov cx, 5000h
_F000:E24C loc_FE24C:
_F000:E24C loop loc_FE24C
only 20000 cycles of delay
_F000:E24E				   add	   di, 2
_F000:E251 cmp di, 10h
_F000:E254 jb short loc_FE23E
repeat until 16 bytes, then reset back to 0
_F000:E256				   mov	   cx, 5000h
_F000:E259 jmp short loc_FE232
feipoa wrote on 2022-12-17, 02:25:
83 | 02 10 | FF E8 | 72 00 | 69 -repeats indefinitely- […]
83 | 02
10 | FF
E8 | 72
00 | 69
bad:
- I dont see any F00F in there
no foof means writes to cache arent saved in cache
- it repeats every 8 bytes instead of 16
8 bytes = 64bits just like Pentium bus/cache width, means it did try to flush cache, but no cache chip was being activated at the moment of reading and it kept reading same garbage maybe from empty memory bus? is the output always the same even if you power down for couple of minutes?
Reply 113 of 126, by feipoa
The values shown on the POST card change approximately every 1 second.
Yes, I tried powering up/down 3 times in total and the output was consistent, as shown above.
We may be at a stand still. I did manage to find a later version of this board, the ASUS P/I-P55TP4XEG. It is based on the same 430FX chipset, has DIP Async SRAM sockets and a COAST slot. There is one jumper on the board that selects between ASYNC and COAST-PB SRAM, so when it arrives, I will see what this jumper is doing. Most likely it is doing something we've already tried, but sometimes I get pleasantly surprised.
The attachment ASUS_P_I-P55TP4XEG.jpg is no longer available
Reply 114 of 126, by rasz_pl
worst case scenario you can stick desoldered coast module in new board and trace pin by pin how cache chips are connected to chipset
feipoa wrote on 2022-12-17, 10:23:
20000 cycles per second? so the cpu must be running with L1 disabled, still that seems really slow 😮
Reply 115 of 126, by feipoa
Let's see how my motivation is at that point. I may even upgrade my socket 5 setup to that of the socket 7 ASUS P/I-P55TP4XEG. After all, it can take 512 KB PBSRAM rather than just 256K.
Reply 116 of 126, by feipoa
I have received my Asus P/I-P55TP4XEG v2.4. Attached is the manual.
The attachment Asus_P-I-P55TP4XEG_for_PCB_rev_2.1_and_up.pdf is no longer available
So far, I've only had time to map out where JP16 goes.
JP16
1-2 = Async SRAM
2-3 = Pipeline Burst
Pin 1 = COAST slot pin 91 = pipeline burst SRAM module pin 86 = OE#
Pin 2 = DIP32 sockets pin 24 = OE#
Pin 3 = 4.7K pull-up to 5 V
The attachment JP16_on_Asus_PI-P55TP4XEG_v2.4.jpg is no longer available
Reply 117 of 126, by pentiumspeed
Good board. I had this one once.
Cheers,
Great Northern aka Canada.
Reply 118 of 126, by feipoa
I attempted to mimic the jumper setting, JP16, from the Asus P/I-P55TP4XEG v2.4 onto the Asus PCI/I-P54TP4 using a 4.7 K-ohm resistor, but it didn't help the issue with the non-functional pipeline burst cache.
I have since desoldered the UMC pipeline burst SRAM from the Asus PCI/I-P54TP4 and removed all other modifications made with regard to PB SRAM. I gave up this effort and am now using the Asus P/I-P55TP4XEG v2.4 with a 512K PB SRAM COAST module in my K5-200 build.
I had really wanted a full length AT socket 5 board for my K5-200 build with PB SRAM, but I've settled for a socket 7 board instead. Perhaps someone else with another 430FX and PB SRAM solder pads can report their findings here.
Reply 119 of 126, by Marco
Off topic:
I also owned the P54TP4 back in the days with 512kb non PB cache plus EDO. and all benches were indeed faster with L2 disabled. Especially when running bus at 80MHz. Never understood why.
Anyway fantastic engineering here so far. Good luck with the new board.
1) VLSI SCAMP 311 | 386SX25@TI486SXLC2-50@63 | 16MB | CL-GD5434 | CT2830| SCC-1 | MT32 | WDC160GB/7200/8MB | Fast-SCSI AHA 1542CF + BlueSCSI v2/15k U320
2) SIS486 | 486DX/2 66(@80) | 32MB | TGUI9440 | LAPC-I
