Reply 100 of 110, by wierd_w
Timings seems more likely.
mr bios wants to run more tightly. Try increasing the ram access waitstates a little with caching on.
Or, changing the cache mode, if it is set to write thru, to write back.
Do not ask Why !
Not really buddy..unless timing adjustments are buried deep and I haven't discovered them yet..
There are 14 pages in the bios ...I'll post them up for you to look at..
..last 4
Vipersan wrote on Yesterday, 16:36:Not really buddy..unless timing adjustments are buried deep and I haven't discovered them yet..
PC150012 😀
side note, which I'm unsure if it's sorta bypassed by using a amd k6/2, the 430TX chipset only caches up to 64M of memory.
Anything higher will suffer some slowdown.
anyway... play around with the first three settings if you feel like it, yes, even the EDO/FPM timing.
I don't know if they might have an effect on the SDRAM you seem to be using.
Do not ask Why !
weedeewee wrote on Yesterday, 18:33:PC150012 :-) […]
There are 14 pages in the bios ...I'll post them up for you to look at..PC150012 😀
Anything higher will suffer some slowdown.anyway... play around with the first three settings if you feel like it, yes, even the EDO/FPM timing.
At this point I have nothing to lose by trying...
No wait state tweaking...and unsure if the fpm edo setting would be relevant...but hey..It took me this long and a lot of waiting..just to discover disabling the cpu cache gets results.
Is it possible or even likely that this industrial setting mrbios was never written or modified to be used with K6-III.
who knows..
certainly not me
Vipersan wrote on Yesterday, 19:28:At this point I have nothing to lose by trying... No wait state tweaking...and unsure if the fpm edo setting would be relevant.. […]
I don't know if they might have an effect on the SDRAM you seem to be using.At this point I have nothing to lose by trying...
who knows..
certainly not me
K6-III ? mmh I only see it reporting a K6/200. no idea though.
MR Bios's tend to have just the settings that one needs, but it tends to support/drive the hardware better from the start, like the 4 floppy drive support.
This in contrast to the AMI bios's where with the use of the correct program, like the old amisetup? (i think that's what it was called), you could change so many settings, some would work, others wouldn't do a thing.
What CPU are you actually running on that board?
also, try running the speedsys benchmark. the graph bottom right should tell you something about memory/cache throughput. Compare them with cache enabled and disabled.
Do not ask Why !
You have me wondering now....
I have 2 of these mobos...one is in a desktop running win98se with my rare graphics card ...a voodoo 5500 pci.
I thought they both were fitted with the same cpu...but it may well be I am wrong..
I'll find out for sure..
cheers
checkit was less than helpful ..it claims it to be an 80486
doh!
Looks like I had this cpu mixed up with another one..
It is indeed a lowly K6 @200m ...cpuZ confirmed it.
A K6-III would be overkill for this system anyhoo.
Had to pop the original bios back in in order to run win98 and cpuz..so will have a play around with those memory settings tomorrow.
My CPU is an AMD K6-III+ and I don't need to disable internal cache.
Here's a few pictures of my BIOS settings. Let me know if you need anything else.
Any possibility you're mixing high and low density memory? I always try to ensure that my memory is as matched as possible. As a test, can you try removing the high density DIMM (has only 8 or 9 chips)?
Another test... Try using an add-in IDE/SATA/SCSI card and install DOS on that. Just in case the MRBIOS isn't playing nice with the onboard IDE.
-Brian
