Reply 1000 of 1098, by PC@LIVE
- Oldbie
For what 😨 I want to thank all those who participated in these discussions, related to motherboards, I'm not going to mention them all one by one, but I'm telling you:
Thank you 1000!
On the MSI MS-6741 VER:1, I just finished working on it, I replaced the damaged electrolytic capacitor, and I added the missing one, respectively a 1000uF 6.3V and a 1500uF 16V, for the replacement I used a Rubycon and a Panasonic, now the VRM area is all Rubycon except the Panasonic, which I put in place of the missing one, but ultimately at least this part should not have future problems, due to poor quality capacitors.
Previously I had written, of an identical motherboard but without integrated video, well it seems that despite having the same name, they are two different models, I don't know if the BIOS is incompatible, already because you have to be very careful to update it, here the chip is welded, so you can only reprogram from floppy, assuming that the Recovery BIOS is working.
The model that has the integrated video card is K8M800, and it is written on a sticker attached in a chip near that of the BIOS, the other card without integrated video, should be a K8T800, in practice two different chipsets for the same motherboard, and I would be quite sure that even the BIOS are different (incompatible!), I just hope that the previous owners did not make an incorrect BIOS update, and that therefore they found an unusable motherboard, this one in particular with K8M800, is perhaps more modern than the other, but this interests me relatively, the important thing for me is that it works, And that you can make a nice S.754 PC, which represents a period of passage between the 462 and the subsequent AM2, I don't forget the 939 but it's from the same period, while the 940 I think is very rare especially in a version with 4 CPUs, here's something like that you could admire it at the time, and for many it was a dream configuration.
Ultimately the card will have to be tested, using everything I used on the ASUS K8U-X, if I have the same problems, I will try something else, if it works well, I will have to try to understand if the K8U-X is repairable, we will see and let's hope well.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
