Reply 10520 of 58653, by PCBONEZ
wrote:Got a 2.66Ghz Xeon 3070 for $9.25. :) This processor debuted at over $500 in late 2006, so I consider it a good bargain. It w […]
Got a 2.66Ghz Xeon 3070 for $9.25. 😀 This processor debuted at over $500 in late 2006, so I consider it a good bargain. It works perfectly in my Intel D946GZIS (a non-server board) and is otherwise identical to the Conroe C2D E6700. From what I've read, the Xeon version tends to run cooler and overclock higher. This is for my high-end XP retro machine and matches up well with the GeForce 8800GTX. It's close to the fastest possible period-correct 2007 system, at least from a gaming standpoint. The previous processor in this system was a 1.86Ghz E6300, so it will be a significant improvement (over 40%). Here is the ebay link (the seller has more):
http://www.ebay.com/itm/intel-Xeon-3070-core- … gEAAOSw-ndTmz-LThe only blemish I give it is my CPU has a green sharpie check on it. No one will ever see it, but it is unsightly when handling and viewing. 🙁
edit: it was a highlighter mark, not sharpie, so it cleaned off easily.Benchmark results coming in the next week or so.
Have you considered the skt 771 into skt 775 mod?
