Reply 1060 of 1134, by red-ray
- Oldbie
RaVeNsClaw wrote on 2025-04-13, 11:08:[…]
- Attached are "Save Local" reports of some old GPUs under NT4.0:
- 3Dlabs GLint MX + GLint Delta
- Number Nine Imagine 128
- Number Nine Imagine 128 II
- Matrox Impression Plus
- Matrox Millennium MGA-2064W-R3
- 3Dlabs Permedia NT
- Ati Rage II + DVD
- Intergraph RealiZm Z13
Thank you for all the reports, with so many I feel it's best to number them so I made them a list=1.
- As MAXDATA set setup in the SMBIOS as the system maker SIV did not realise the board is an ASUS CUBX. This meant all the Temperatures, Fans Speeds and Voltages were not reported. The fix was trivial and is in the attached test SIV32L V5.81 CUBX-04, please use this for all future tests.
- SIV did OK, do any 3rd party utilities do better and if so which and in what way?
- SIV did OK, ...
- I needed to add Imagine 128 II support. I assumed it's much the the same as the 128, is it? How does SIV32L V5.81 CUBX-04 do?
- I tried to add Impression clock reporting some time ago and suspect the clock speeds can't be read, do any 3rd party utilities report the clock speeds?
- I also have a MGA-2064 so SIV does OK.
- SIV did OK, ...
- The speeds of 1.98GHz seem too high, what should they be?
- I have added RealiZm Z13 to pcidevs.txt. SIV found the Intense3D Wildcat 4000 twice, I wonder are two installed? Please so SIV32L -DBGGPU -EXIT=10 > SIV_DBGOUT.log | MORE and post the .log file.
Is there anything you have spotted I have missed and need to fix please?
