Wow, that looks like an interesting lot of well kept and varied computer hardware - I like the shelf with the current model optiplex just across from a late 70's machine 😁
The last few days I've been performing repairs on a couple of motherboards I got - the 386DX MA013 board I washed under the tap the other day isn't posting, no CPU activity at all, which is a shame.
The other one though - a late revision Asus PVI-486SP3 with a *ton* of damaged traces, that one has been slightly more fortunate. It took quite a while to repair but it's very tidy considering that those traces are pretty small, I probably couldn't fix a modern motherboard this way though.
The keyboard controller was bashed in, sitting at a bad angle with a broken pin. That appears to work after bending it back and soldering a replacement pin, then fixing all the damaged traces leading to the keyboard controller.
While looking close up at the CPU socket, it looks like the hit to the underside of the board that caused those deep scratches also caused loose joints on a lot of the pins so I went over those too with fresh solder.
I thought it was broken initially because I got no video output with a post code of "4E" which with an AWARD bios means POST error and I assumed it wasn't working? So I went to bed instead.
Today I had another go with another monitor and got display, the POST error was 'no keyboard' / 'bad CMOS values' - but it's working, which is wonderful, though maybe a PCI slot is dead or something. I should probably let some of the other 486 boards go now with this swiss army knife of a 486 board 😀
I had been using my AST Bravo 486 / 586 with the same SiS chipset but it's become so annoying, a well supported and standard board like this one is very preferable.
