Reply 1080 of 1409, by Artex
- l33t
imi wrote on 2021-03-18, 19:02:Artex wrote on 2021-03-18, 18:51:Now my issue is that I need to deal with the audio piece. I was under the assumption that the second 3.5mm jack on the OSSC could be assigned/linked to any of the input connections. VGA/DSub is RGBHV / AV3 (or button 3 on the remote) but there is no audio out jack for this particular input - it's all HDMI. The output jack can be used as an input for AV2/Component sources or as an output only for AVI1/SCART sources.
So now do I need another box to convert HDMI (Digitized VGA + Audio) to DVI + 3.5mm audio which then would go into my motherboard's line-in for audio capture along with the video from the VisionRGB card?
why not just feed the audio into the PC line-in directly?
no point to go through the OSSC if you don't want to output audio via hdmi.
Wow - I'm an idiot. Sorry... Apparently I like over-complicating things. 😀
