EAX appreciation thread
Reply 1100 of 1173, by Joseph_Joestar
AndreaColombo86 wrote on 2026-04-23, 18:19:
Joseph, I think it was you who mentioned that Baldur’s Gate 2 outputs 5.1 surround sound when EAX is enabled. Do you know whether that is the case with the first Baldur’s Gate as well?
I think the original Baldur's Gate was just 4.0, but it's been a few years since I tested that.
I wonder if I can get surround sound from it when playing the BG Trilogy mod (which essentially ports the first game to the second game’s engine.)
No idea.
If the game is capable of 5.1 surround, then CMSS-3D should be able to virtualize that for headphones. Should I set Windows XP to 5.1 and the Creative control panel to headphones for optimal performance?
From my experience, that tends to vary from game to game. Try both 5.1 and stereo (or headphones) for speaker settings and then pick whichever sounds best to you. Nowadays, I always play with a proper (physical) set of 5.1 speakers, so I can't really say what's better for headphone use.
My retro builds
Reply 1101 of 1173, by AndreaColombo86
Tangentially related question: how do you handle surround-speaker positioning? My problem with 5.1 speaker setups for computers was always the impossibility to properly place surround speakers without them getting in the way. Where I have my PC now, I just couldn’t fit them: They’d be right in the middle of my room and I would knock them over all the time.
Reply 1102 of 1173, by Joseph_Joestar
AndreaColombo86 wrote on 2026-04-23, 20:00:
Of course, everyone's situation is different, but here's what works for me. My front left and front right speakers are on their respective sides of the desk. The front center speaker is below the monitor, and the subwoofer is under the desk. The rear left and rear right speakers are behind the chair that I sit on while gaming. When not in use, I can roll up the cables of the rear speakers and tuck them away under the desk.
That said, for the optimal acoustic experience, it's probably better to use a home theater sound system that is properly positioned inside a dedicated room. I don't own one of those, so someone else is better suited to explain that in more detail.
My retro builds
Reply 1103 of 1173, by AndreaColombo86
Are you using a CRT screen? What solution did you adopt to fit the center speaker underneath it?
I do own a dedicated home theater system (well, my dad does), but my retro PC is in my room and my gaming PC is in the living room, so that’s a no go 😀
Reply 1104 of 1173, by Joseph_Joestar
AndreaColombo86 wrote on 2026-04-23, 20:41:
No, I use a 16:10 LCD monitor for Win9x and WinXP gaming. Specifically, the ASUS ProArt PA248QV.
It has a stand which allows me to adjust its height. When the stand is fully extended, the front center speaker fits nicely under the monitor.
My retro builds
Reply 1105 of 1173, by RetroGamer4Ever
Back in the days of yore, the speakers were small in size and some models had stands that you could buy separately, so you could position them wherever and whenever you needed to.
Reply 1106 of 1173, by NeoG_
I re-arranged my study so the retro station (connected via KVM to the 98 and XP boxes) is at the corner of a large corner desk so I can put the rear speakers on the ends of the corners without taking much if any space. It helps that they are tiny cubes from an FPS1000 system.
Reply 1107 of 1173, by badmojo
NeoG_ wrote on 2026-04-25, 04:11:
I re-arranged my study so the retro station (connected via KVM to the 98 and XP boxes) is at the corner of a large corner desk so I can put the rear speakers on the ends of the corners without taking much much if any space. It helps that they are tiny cubes from an FPS1000 system.
That looks good; it's hard to find a solution that works for the satellites. I read heaps of guides on height and position and I'm sure it all makes a difference, but not many people have a dedicated room to get it all 100% perfect. My desk was in a corner and I ended up turning it to sit 90 off the wall, and then mounted the satellites on the wall behind me.
Reply 1108 of 1173, by sharangad
I had the inspire 5300s with the official stands.
My desk was in a corner and I ran both rear speaker wires against the side wall and one of them behind my chair. I had to get up in a certain direction.
Later upgraded to Logitech 5300s and later z5500s, which annoyed my upstairs neighbor. I wound up switching to headphones.
https://patreon.com/Rready
Reply 1109 of 1173, by AndreaColombo86
Has anybody tested the EAX in WarCraft III? Is it good? Does it also have surround sound?
EDIT:
While we’re at it, does anyone know whether Icewind Dale, Icewind Dale 2, and Planescape: Torment also have 5.1 surround sound when enabling EAX?
Reply 1110 of 1173, by Joseph_Joestar
AndreaColombo86 wrote on 2026-04-26, 20:30:
WarCraft 3 uses EAX 2.0 and supports 5.1 surround. It's been a few years since I replayed it, so I don't remember every detail, but I think EAX was mostly used in caves and similar environments. Note that patch 1.30 removed EAX support from the game.
Icewind 1 and 2 are stereo only, and they barely use EAX. Planescape has 5.1 surround and makes decent use of EAX in dungeons and such. Also, a slight correction on the original Baldur's Gate - the base game had 4.0 surround, but either the expansion pack or one of the later patches added 5.1 support. More details here: List of Win9x games with surround sound support
My retro builds
Reply 1111 of 1173, by AndreaColombo86
Thanks for your feedback 😊
EDIT: this is only tangentially related, but does anybody know whether the first Max Payne implemented sound occlusion / obstruction in any way, despite not supporting EAX?
I doubt it, but I can’t seem to find a definitive answer. AI thinks it supports EAX, so that’s completely useless.
Reply 1112 of 1173, by Joseph_Joestar
AndreaColombo86 wrote on 2026-04-27, 10:18:
Off hand, I don't recall anything like that. But it's been four years since I last replayed Max Payne, so my memory is a bit fuzzy.
I do remember it having good positional audio on my 5.1 speaker setup, so there's that.
My retro builds
Reply 1113 of 1173, by RetroGamer4Ever
MP2 had the full audio experience. MP1 just had basic hardware accelerated audio, within the DirectSound API and whatever effects the devs chose to use, in that period where EAX and DirectSound were linked and every card had EAX1/2 functionality.
Reply 1114 of 1173, by niceguy2
Joseph_Joestar wrote on 2026-04-27, 05:27:
Do Planescape and BG1 work fine in XP with WDM drivers or is it like BG2 where they have issues properly implementing the full EAX features? I assume BG2 being EAX 2.0 [w/occlusion] vs. the others in 1.0 means it's a different scenario (moreover, it's a different game altogether so different development history could have yielded the different results regardless)? Tangentially related, does BG2 have occlusion via A3d (and for that matter is A3D better to use in that game, as can often be the case from that era, though not exclusively as I understand it)?
Reply 1115 of 1173, by Joseph_Joestar
niceguy2 wrote on 2026-05-21, 17:38:
Not sure, I haven't done enough testing on those games to reach a definitive conclusion. They support EAX 1.0, so occlusion shouldn't be an issue, unless the developers added some extra EAX 2.0 functionality in the later patches, which is unlikely. Again, I haven't played them as much as Baldur's Gate 2, so I can't really say for sure.
From my admittedly brief testing, I was unable to turn on environmental effects in Baldur's Gate 2 when using an Aureal Vortex 2 sound card. So I don't think it supports A3D at all.
My retro builds
Reply 1116 of 1173, by niceguy2
Understandable, I know that's a lot of testing (and not surprising that the reporting of A3D in BG2 might not be correct/was originally planned or the like since that seemed to have occurred on numerous occasions).
I'm trying to decide if I want to add an Audigy 2 to a 98 build I'm going to be doing (Diamond MX300 is the primary sound card since A3D is my priority), but I'm not sure if it's worth the potential conflicts of dealing with two sound cards if it's only a couple of games that really need it (maybe more are out there we don't know about of course). I have a separate XP setup with Audigy up through version 4.0 so pretty well covered on the EAX front otherwise.
I know you've done exactly that in one of your builds so it seems like it's possible, maybe worth me grabbing an Audigy 2 to see if my mobo/chipset will handle it (Asus TUSL2-C). You have both installed with drivers and everything simultaneously and it plays nice? I saw your issues with the ZS vs. non-ZS but not necessarily problems with the Vortex conflicting?
Reply 1117 of 1173, by Joseph_Joestar
niceguy2 wrote on 2026-05-21, 18:56:
The way I did it is as follows. First, I dual boot Win98SE and WinXP, both of which are installed on separate physical drives (or rather SSDs). I choose which drive to boot from by selecting the appropriate option in the BIOS. Second, on my WinXP drive, I have two images of the disk where Win98SE resides. One image has the Aureal Vortex 2 drivers installed, while the Audigy 2 is completely disabled in Device Manager and its drivers were never installed. The other image is the opposite of that, i.e. Audigy 2 drivers are installed while the Vortex 2 is completely disabled. I can restore those images as needed in just a few minutes.
That's what worked best for me, as I didn't want to mix the Vortex 2 and Audigy drivers, fearing potential conflicts. There 's probably a better approach for this, i.e. using a boot loader to establish a true multi-boot environment, but I like to keep things simple. Technically, it would have been even easier to just have two Win98SE installs (one per physical drive), but I prefer to have WinXP for maintenance purposes.
My retro builds
Reply 1118 of 1173, by AndreaColombo86
Am I understanding correctly that I could, potentially, install two sound cards on my retro machine (say, a Sound Blaster Live! 5.1 and an X-Fi Titanium Fatal1ty) and just have different images of Windows XP to restore with the click of a button so I could use both?
If yes, may I ask for a step by step guide of how to set that up? Do I need two different hard drives?
Reply 1119 of 1173, by Joseph_Joestar
AndreaColombo86 wrote on 2026-05-22, 10:31:
Sure, and it should be even simpler with WinXP. But I suggest opening a new thread for that, as someone more knowledgeable about multi-boot environments might be able to offer more help.
As mentioned above, the approach that I use on my Vortex 2/Audigy 2 PC is suboptimal. And while it works well enough for my particular use case, I can't say if it would be suitable for someone else's system. Other posters on this forum have had great success with third-party boot managers like Plop, and were able to boot multiple operating systems ranging from DOS 6.22 to Win7 on a single PC using one large drive. So it might be worth consulting those people about the process, as my own experience with that is very limited.
My retro builds
