Reply 11140 of 30571, by bandicoot67
Finished mounting a 1995 Mech Warrior 2 shop promo poster to some ply wood with bits n pieces stripped from a dead older style plasma TV.
Its worked out ok i guess.
Reply 11141 of 30571, by kaputnik
appiah4 wrote:
kaputnik wrote:
Got my 3D printer assembled and up and running the other day, been working on a simple 3D printable I/O shield this morning. First blank prototype printed:
Now off to fine tune size, hadn't taken thermal expansion into account, and make connector cutout templates.
Oh, and will gladly share the models once they're done 😀
Oh nice, what material are you printing it with?
Would be very happy if you would share the model for blank, AT and old style ATX backplates 😀
Decided not to do separate models for different materials, it's easiest to just scale it in the slicer to compensate for thermal expansion. The model got the desired dimensions. 100.5% scale was good for ABS (which I used during testing) in my printer. Haven't tried PLA, but it should do with less scaling, since its thermal expansion coefficient is lower, and it prints at lower temperatures.
The attachment io3.jpg is no longer available
Attached the blank model (Inventor model + .stl export).
What do you mean by AT and old style ATX backplates? Is the latter one for that connector configuration just about all mobos had back when ATX was relatively new?
Edit: also added another version of the blank shield, with recesses letting it snap into place in the cutout:
The attachment io4.jpg is no longer available
Reply 11142 of 30571, by amadeus777999
brostenen wrote:
Playing with SCSI. I get just under 8ms seek time and some 33 to 35 megabyte a second transfer rate, on these IBM Ultrastar 9gb 10k RPM's running on a Pentium-166. I used a 68pin cable and an Asus PCI Controller.
SCSI seems awesome - it took me a good 20 years to finally sniff around and buy drives and controllers. Unfortunately I got several 80pin ones and only one 68pin one which fits the cards I purchased. On the downside the controllers with the cache modules do not work in Win98... so I'm left with one 2940UW.
How to get the drives working in DOS when using the 2940(which seems the most compatible/common)?
Reply 11143 of 30571, by ynari
'SCSI seems awesome' - that's an idealised overview of someone that's never used it, that's for sure.
Yes, it can be quite good *if* all the devices work together, you have decent cables, no termination issues, and decent drivers. Not to mention the huge variety of cables, and adapting from one SCSI standard to another. The whole SCSI stack is too large under DOS to effectively use, it's basically limited to protected mode operating systems.
It was generally a happy day when parallel SCSI went away (not to mention odd stuff such as FC AL)
Reply 11144 of 30571, by Whelmy
Got a pentium 200mhz today to test on the unisys aquanta sc. Officially it only supports up to 166mhz but I figured well there's another combonation of jumpers that could be used that are not listed on the diagram so let's test that shall we.
The attachment IMG_0467.JPG is no longer available
The attachment IMG_0469.JPG is no longer available
Success 😀
Reply 11145 of 30571, by liqmat
Whelmy wrote:
Got a pentium 200mhz today to test on the unisys aquanta sc. Officially it only supports up to 166mhz but I figured well there's […]
Success 😀
I think it's great you got the system running at 200MHz, but please... hold your hand still on those photos.
Reply 11146 of 30571, by Whelmy
There's a reason I can't solder, and it's sadly the same reason my photos turn out the way they do most of the time.
Reply 11148 of 30571, by Whelmy
bjwil1991 wrote:
Ouch, man. Have you used a tripod, and is it a digital camera?
Good idea, a tripod is something I should look into investing in probably.
Reply 11149 of 30571, by Xicor
kaputnik wrote:
Decided not to do separate models for different materials, it's easiest to just scale it in the slicer to compensate for thermal […]
The attachment kfd5b.jpg is no longer available
Reply 11150 of 30571, by kaputnik
Xicor wrote:
Thanks 😀
Printed a shield with cutouts for the 440LX board sitting in my test rig, finished a few moments ago, still on cooldown:
The attachment xXtFWV5.jpg is no longer available
Wonder if it fits? Quite hard to get the measurements right :>
Reply 11151 of 30571, by brostenen
This:
https://www.ebay.com/sch/i.html?_from=R40&_nk … sacat=0&_sop=15
Just pick those that can be used for both 68 and 50 pin controllers.
In Dos I am using different controllers, both PCI and ISA types. I only have 50-pin when we are talking about ISA, yet I have an Asus that can be used for both 68 and 50 pin cables. (not simultaniously)
Reply 11152 of 30571, by kaputnik
Didn't turn out too bad after all 😀
The attachment IMG_20190212_211604.jpg is no longer available
Reply 11153 of 30571, by brostenen
Most if not all of my drives, have internal termantors. It can be set by a jumper. That goes for all my Cd-Rom drives, even my old 50-pin 4x speed Plextor that uses caddie's. My Zip drive (50-Pin) have internal terminator as well, and my IBM have auto termination as far as I remember. They must have, as I use no terminator on that 68-Pin cable.
EDIT:
Yes... It IS awesomme technology. Yet like you mention, it comes down to the drives. Avoid loud drives, and drives that put out too much heat. The technology in it self are so much more awesomme than IDE, because the way you do the setup, are so much more awesomme.
Reply 11154 of 30571, by brostenen
TOTALLY AWESOMME.... 😮 😜
Reply 11155 of 30571, by bjwil1991
I should get me a 3D printer and make an I/O shield for an AT motherboard or for the motherboard my brother has since the I/O shield went missing on there.
Reply 11156 of 30571, by appiah4
Amazing job. Now please make one for AT motherboards and post the file 😉
Reply 11157 of 30571, by Thermalwrong
That's excellent 😁
Well done making that so accurately and thank you for sharing the STL files for it, I have a couple of boards I need to make something similar for, that I'd rather 3D print than try to make myself. Some of the designs on Thingiverse etc are quite good, but yours looks like it's designed very well, so I'll use that instead.
I bought a few blank panels, but cutting the shapes of a few of the ports is too difficult for me.
Reply 11158 of 30571, by gdjacobs
Noice. Any thoughts on an outer conductive coating? Apparently carbon and acrylic are a good, inexpensive solution.
Reply 11159 of 30571, by x0zm_
Here's... something. I think it's a crime against humanity. It shouldn't be allowed.
I still had this bit of wire from the terrible heatsink inside a Compaq machine I salvaged the CPU from.
I also had this AIO sitting around that I found ages ago inside a Noctua box.
The two items ended up in the same room together and I got to thinking...
Turns out that nicely bent piece of wire can be used to mount other types of cooling devices to Socket 7 CPUs.
Stock heatsink for scale. 🙄
Sure beats having to cut out sheet metal for mounting stupid things to CPUs. 🤣
I can confirm it stays on when the board is vertical and the radiator is fastened or supported by something else.
This has been today's pointless retro exercise. Unless I end up actually using it. 😵
