Reply 1120 of 3289, by chuky
If you're interested I've collected most Tomb Raider patch versions. Here are all the versions for the Rendition Vérité. I haven't made a post yet but they were hard to find. The .uc files seem to be the same in all versions.
Reply 1122 of 3289, by sharangad
chuky wrote on 2024-04-23, 12:16:
Thanks @chuky. What're the differences between them? Are they significant enough to test one by one?
https://patreon.com/Rready
Reply 1123 of 3289, by sharangad
robertmo3 wrote on 2024-04-23, 11:44:
all tr games have swimming pool inside 😀
I briefly played TR2 back in the 90s. I seem to remember a pool outdoors. Can't remember the indoor areas very well. There was a butler who bumbled about.
Reply 1124 of 3289, by sharangad
Rendition Ready in 4k without front buffer capture.:
https://youtu.be/v7eWNE8iiVk
In fullscreen mode front buffer effects can't be captured, unless you're using an external capture device or something clever.
Reply 1126 of 3289, by chuky
There are changelogs for the Tomb Raider patches. Older ones disable mipmapping by default, have a lower quality mipmapping and don't have the water deformation effect.
Reply 1127 of 3289, by sharangad
chuky wrote on 2024-04-23, 12:42:
I did grab the zip, but won't be able to actually test anything until tomorrow. There's a tropical thunderstorm here and lightning strikes/sudden power outages are common. If it's not an outage the frickin breaker trips.
Reply 1128 of 3289, by sharangad
As a quick performance test and for some early feedback (for ICR2 only) an alpha build (an actual alpha not like the regular RReady Alpha):
Only for ICR2 (still extremely buggy).
[EDIT2]
Smaller pipe slow but stable[Not recommended):
RReady Alpha^3 (20240426)
https://1drv.ms/u/s!As-dKk-N73dSmHF4CMlMCmq6Nggx?e=0UpUZq
(Recommended) Large pipe buffer, randomly unstable (but not that unstable 😀. My videos use a larger buffer):
RReady Alpha^3 (20240426) 003.
https://1drv.ms/u/s!As-dKk-N73dSmHSbI_Oqe9qKW0qP?e=4kNO9T
MD5: 31b7f5b1e3333d48084f1d7123fa6ea8
[/EDIT2}
MD5: cab8882533e459fe1e8d8fd5fadff4df
Dosbox Alpha^3 (20240426)
https://1drv.ms/u/s!As-dKk-N73dSmHIlbDF7JglTLDO4?e=nnboFN
MD5: c860b3dae811542cd65d860cd8c08928
[EDIT] You'll need a temp folder in C: drive.
Dosbox-Rendition and DosClient source is available here https://sourceforge.net/projects/dosbox-rendition/.
Dosclient and dosbox-Rendition are GPL 2.0 and Dosclient has a license exception to support closed source system libraries like the Rendition ones. A compatible V1000 BIOS (VBI files) has been supplied. Other BIOSs will not work. Certain parameters have to be configured for each BIOS and this release has hard coded parameters for the supplied BIOS.
Download and unzip the dosbox package and and add dosbox as an application to RLauncher. Always launch Dosbox from RLauncher as this will update dosclient.
DO NOT RUN MORE THAN ONE Speedy3D APP IN SEQUENCE. Close Dosbox and relaunch it from RLauncher. This means no cartfast,bat or cartsafe.bat run cart.exe or indycar.exe directly. RR.exe still has issues.
This is only for ICR2 and it will still be buggy. You can try running other Speedy3D apps but they're not supported in this release. NR1999R has regressed and will not work correctly here.
This release is to gauge whether the CPU requirements are too high. I *think* you'll need at least a quad core and a discrete gpu.
Hopefully during testing nothing disgusting will happen. I've shrunk the named pipe buffer down, so the CPU load will be higher, but more stable.
Reply 1130 of 3289, by robertmo3
whiplash
Reply 1133 of 3289, by sharangad
I've got fifo speeds on par with DMA mode. Descent II seems to use fifo mode and produces nothing on screen.
[EDIT] I'll do another build tomorrow.
Reply 1134 of 3289, by robertmo3
it has to be whiplash (not fatal racing)
fatal racing doesn't work
it works but very slow
once the black screen with "rready rendition alpha 1" appears, you have to wait 20 seconds for the game to start showing fps counter, few more seconds you got game logo, and intro starts with very slow 1 fps
Reply 1135 of 3289, by robertmo3
it is interesting you can copy "rebel moon rising" folders to "rebel moon" game
It works in original dosbox 0.74-3 with "rebelmoon.exe -vga" switch,
but doesn't work in dosbox-rendition.
Reply 1136 of 3289, by sharangad
robertmo3 wrote on 2024-04-27, 10:24:
It works in dosbox with "rebelmoon.exe -vga" switch,
There's some no-standard VGA behaviour with DOsbox-Rendition. I need to fix that as well.
Reply 1137 of 3289, by robertmo3
i don't care about rebelmoon.exe -vga
but rebelmoon.exe doesn't work too in rendition mode 😉
ef2000 complains about missing vesa support
Reply 1138 of 3289, by robertmo3
NASCAR Racing II works
Scorched Planet freezes on red screen
Reply 1139 of 3289, by sharangad
robertmo3 wrote on 2024-04-27, 10:22:
it has to be whiplash (not fatal racing) fatal racing doesn't work […]
It's probably a FIFO based game. I've got FIFOs speeds on par with DMA now. Will do a release tomorrow.
