Reply 11560 of 59678, by Ozzuneoj
- l33t
wrote:It's a kickass card, the onboard amp is a killer, you can control the mixer from the command line, the FM is thick and bassy and they are all-round good cards. The SB compatibility is pretty good too. You can also control the volume in Windows with key combinations without opening a mixer.
Be warned - the CD Audio header has a funky pinout, something like G R G L G I believe.
Something else awesome; Near the SCSI interface, you can see a little 4-pin header. If you plug a speaker into that header and have nothing in the Line Out jack, sound will play through that speaker inside the case. Don't go nuts though, the amp is pretty strong and I've damaged a 2 Watt speaker with mine before (On purpose, given it was wrecked already) so if you start making it distort you should really back off if you don't want the speaker to break. The rear jack also passes this amp, so you can use those crappy passive speakers and still get nice loud sound.
Very interesting! Is it likely that this card would work okay along side my CT2940+CT1920 setup? It'd be cool to hear the different types of music back to back to compare them.
Also, what kind of wattage and impedance are we talking about with that amp? I build speakers and have several at my disposal. Loose or in cabinets. Is the internal connector stereo? This is really cool... I've never heard of an amplified internal speaker connector on a sound card. I'm picturing an old dual voice coil midrange speaker I have being powered by my sound card. 😊
