Voodoo2 diagnostics software (Witchery)
Reply 120 of 124, by zuldan
Apologies if this is a silly question but how do you get the log file out of Witchery when run with LOADLIN.EXE?
Reply 121 of 124, by quattro64
I'd also like to know this ^, I am running witchery from freedos usb stick. And thank you fagear for looking into my ramdac error. I did try to run with the -e3 option, got the same results except it dropped one line in the possible connections to check, the pin 63 = pin 43 line between fbi and ramdac isn't there using this option.
And an update on my sli board(when connected to this mainboard). Witchery did accurately describe the correct fb ram chip to check/replace and now my sli board passes all witchery tests.
Reply 122 of 124, by Fagear
zuldan wrote on 2026-07-20, 08:50:
You type "ds" to get NC/VC/MC-like lightweight file manager to copy logs to automounted drives.
The attachment 2026-07-22 21.18.38.png is no longer available
The attachment 2026-07-22 21.17.01.png is no longer available
New BIG soundcard: FMonster.
Covox Sound Master replica
Innovation SSI-2001 replica & DuoSID.
My audio/video collection.
Reply 123 of 124, by zuldan
Fagear wrote on 2026-07-22, 18:20:
You type "ds" to get NC/VC/MC-like lightweight file manager to copy logs to automounted drives. […]
So simple, thank you
Reply 124 of 124, by Tiido
Fagear wrote on 2026-07-17, 23:33:
May I ask here? What log filename is better in you opinion: 1) 260717_22-26-28_witchery.log 2) witchery_260717_22-26-28.log […]
May I ask here?
Definitely name preceding the date, otherwise things get lost between other files. Year should be 4 digits, it sorts "better" and avoids any confusions with what order different bits are.
I don't think seconds are necessary with time, the tests take forever and you won't get things happen within the same minute...
