Reply 1240 of 1447, by dr.zeissler
thp wrote on 2023-10-24, 19:48:Update on the AD1980 issue. Was doing some test builds and dr.zeissler tested over the last two weeks with some back-and-forth. […]
Turns out we were quite close to the real answer to begin with, 3 bits need to be set on the MISC (0x76) register:
0x4000 - AC97NC
0x0400 - HPSEL
0x0020 - LOSELPull request for upstream SBEMU: https://github.com/crazii/SBEMU/pull/35
Sorry for going back for that solved AD1980 issue...is this the fix for linux for this issue?
That would be a big step forward if this is already added to amithlon kernel4
https://github.com/SnkBitten/amithlon4/blob/m … plugin_ad1980.c
Doc
