Reply 12760 of 30123, by Mister Xiado
That's a plug for a fan. The system keeps time well enough, despite being off for days on end (switched off with a power splitter), but I have no earthly idea how it keeps time with no visible battery or discernible capacitors for the purpose. I highly doubt they're on the underside of the board. The newer Pentium system I put together had a completely dead CR2032 that I replaced while I was setting the CF card up.
Edit: It seems to have quit keeping time now, so I'll just ignore it.
Reply 12761 of 30123, by RandomStranger
So I've been looking at this card:
RandomStranger wrote:
It's been a while again since I've been here. Last week I've been browsing a local online flea market and found something listed […]
It's been a while again since I've been here. Last week I've been browsing a local online flea market and found something listed as an "Inno3D Innovision PCI videocard" untested, but just for 1.60$ which with shipping came out to be about 4.30$ total. I wanted one for a while for my 450MHz Deschutes build but 100$ on ebay wasn't the price I'd pay with a smile. It arrived today but sadly I have to wait until the weekend to check if it actually works. 😒
Over all it looks to be in decent shape. A bit dirty, there is a little bit of spider web in one of the heatsinks so I hope for the best.
It doesn't instantly break the system and using the pass through cable of my Voodoo 1 it does pass through, however Windows XP (for testing purposes) doesn't seem to see the card at all. Not even if I refresh Device Manager. Any idea?
Reply 12762 of 30123, by derSammler
First, give it a good clean. Then check for broken traces and bent pins on the chips. Also clean the PCI contacts.
Reply 12763 of 30123, by RandomStranger
No sign of physical damage and gave a good bath in isopropyl alcohol and some rubbing. It's as cleand as the first day it came out of the factory. No change.
Reply 12764 of 30123, by kaputnik
Got a text from an old subcontractor a few weeks ago. Knowing my interest in retro computing, he asked me if I happened to have an Asus P5A-B board to sell. Told him no, sorry, and asked what he was gonna use it for. Turned out he's repairing an old CNC mill, that's controlled by a built in MS-DOS PC with that particular mobo and a custom ISA I/O card. Figured any baby AT board would do the job, and offered to swap a tested and working Lucky Star board for the broken P5A-B.
So, today I finally got the P5A-B in my hands. It's the 1.04 revision. Cleaned it off, and checked it visually. Everything looks good. Can't wait for Wednesday, when I'm going home from work, and start the project to get it back to life again 😁
Reply 12765 of 30123, by Almoststew1990
Today I moved house.
I didn't realise just how much PC stuff I had until I had to move it all. I only have four cases, including my modern PC, but the amount of random cards, boxes of screws, games, IDE cables, motherboards, box of CPU coolers and fans... I shudder to thank how much stuff serious collectors have!
Reply 12766 of 30123, by CelGen
My goal today was to crimp an SLI cable for a friend who I gave a second Voodoo2 and pointed him at the mismatched driver kit. Didn't want to use one of my own floppy cables so I went to out local hackspace and dug through their bin of ribbon cables for the parts.
Found an SLI cable at the bottom of the bin, so I came in wanting to crimp one cable and left with two!
Reply 12768 of 30123, by Caluser2000
The president of the local Woodworkers Guild decided to give LibreOffice a try on Linux Mint installed on a P4 system. She's pretty laid back and picked it up without breaking a sweat.
The attachment grandma.jpg is no longer available
See. Even Grandma can handle using linux.
The monitor is a re purposed SONY BRAVIA someone left at my old work place on the counter by the secure exit. It had a note attached saying "free to a good home". I've set autosave for 5 minutes just in case. Good for those of us with failing eyesight.
She's the one of the first women in NZ to complete a Maori carving course. Being a whitey though didn't go down well with some of the brown male folk who couldn't match her skills. Despite the fact she suffers badly from arthritis.
The attachment 20190902_192254[1].jpg is no longer available
Reply 12769 of 30123, by GigAHerZ
Went through my collection of 72pin ram sticks and tested each of them and put stickers on them with the size. No more mysteries about the size of each stick.
Total count ~50. Even found 2x32MB 60ns sticks i wasn't aware of, and 16MB 50ns stick that might be handy on some extreme overclocking. 😀
A little about software engineering: https://byteaether.github.io/
Reply 12770 of 30123, by appiah4
Holy shit those boxes of software next to her - are those boxes and boxes of IBM OS/2 software hers?
Reply 12771 of 30123, by Sedrosken
The bit about the Trident card being unable to run higher than 256 colors -- my C&T accelerator in my 486 laptop is the same way. Under 95 the Chips and Technologies Accelerator (new) driver said I can push hi-color (16 bit) to my display but then I'd reboot as part of the setup and it would yell about my settings being invalid. I fiddled with monitor drivers, thinking maybe I had the wrong one installed that way, but no... Load up speedsys and it only sees 960K of VRAM which I thought at first to be the cause, but I thought you could push 640x480x16b with only 512K?
It's pretty much moot at this point because I've left Win95 behind, just elected to go full-on DOS 6.22 on it since I don't technically have any other systems running plain old real MS-DOS 6.22 and not 7.x. I may eventually go back to 95(B this time, for FAT32) since I have a bigger hard drive (well, SD card actually) in it now and having it split into two FAT16 partitions annoys me more than I'd like to admit.
Glenden Wood is just full of surprises. I keep throwing games at it that it shouldn't really be able to run at all, since the Thunderbird barely even got to the title screen -- stuff like Doom 3, The Sims 2, Psychonauts, and Serious Sam 2. Stuff that in reality is far better suited to a fast P4 or A64 system with a much better video card and double if not quadruple the RAM. I have to sometimes push the resolution down and cut down the settings, but overall it's running this stuff rather well. Especially by comparison!
Shoushi: Dimension 9200, QX6700, 8GB D2-800CL5, K2200, SB0730, 1TB SSD, XP/7
Kara: K7S5A Pro, NX1750, 512MB DDR-286CL2, Ti4200, AU8830, 64GB SD2IDE, 98SE (Kex)
Cragstone: Alaris Cougar, 486BL2-66, 16MB, GD5428, CT2800, 16GB SD2IDE, 95CNOIE
Reply 12772 of 30123, by oeuvre
played some jet slalom
Reply 12773 of 30123, by Caluser2000
Nah they're mine. I have v3 Warp on a DEC PC 486DX2/66 setup with 16megs of ram. I collect OSs of all sorts. Have done since I bought my first 286 back in 1990 or so. You haven't seen what I have in the shed 😀
Early to mid '90s was an interesting time wrt x86 OSs then later on with NT, BeOS and Linux popping it's head in. I think the x86 is the most interesting arch wrt the variaty of operating systems available to it. With the release of Pentium 133s up there were very useful.
A closer look.
The attachment OSs.jpg is no longer available
Reply 12774 of 30123, by appiah4
Whoa. Are you me? I've owned boxed and run (as my main OS) every single one of those OSes in that photo between 1994-2000... I still own all of them except the RedHat 5 and 6 boxes, which I have misplaced (I still have SuSe 7 and 8 boxes though) but that's an amazing coincidence..
Reply 12775 of 30123, by Caluser2000
Seen as you mentioned SuSE 7:
The attachment SeSU.jpg is no longer available
And as a bonus:
The attachment APC2000.jpg is no longer available
Started thread on *nix related stuff. *nix software and systems Feel free to join in. The young upstarts are welcome as well if they want to know a little but more about computing stuff outside the norm.
Reply 12776 of 30123, by appiah4
So cool. Nice to get to know an OS/2-Linux guy. Have you used OS/2 extensively? Warp 3 was my primary OS between 1995-98 and I ran my BBS on it. It was also my introduction to Dial Up Networking and the Internet. O have such fond memories of that OS. There was something about it that just reminded me about Amiga OS, which is also very nostalgic to me. It's a shame I could never afford Warp 4 in that time frame and eventually moved to Win98/Linux dual boot in 1998 (then to Win2K/Linux in 2000).
Reply 12777 of 30123, by Windows9566
which sound card should i use for my P100 DOS 6.22/WFWG 3.11 build, a Sound Blaster Pro 2.0 CT1600 or a Sound Blaster 16 CT1740?
R5 7600X, 32 GB RAM, RTX 3060 TI, Win11
P3 750, 384 MB RAM, Matrox G400, Sound Blaster 32, Win98
PMMX 166, 64 MB RAM, S3 Virge DX, Aztech AZT2316R, Win95
486DX2 66, 32 MB RAM, Cirrus Logic GD5430, Aztech AZT2316, DOS
Reply 12778 of 30123, by appiah4
Neither; the Pro 2.0 really deserves to be in a 386/486 and the CT1740 is a very noisy sound card; but if you had to choose between the two for that system I'd say go for CT1740.
Reply 12779 of 30123, by Shagittarius
Go with the CT1600, I've got one of those in my P90, it's a great choice.
