Reply 13520 of 58873, by Lukeno94
wrote:I loved my dual slot 1 machine - P3 500 to start, then P3 1GHz. I kept it as my main system until upgrading to a Core2 system; it rankled that after the P3, multiple CPUs became uneconomic for the average user.
Slot 1 CPUs tend to be annoyingly noisy, though, with their tiny fans. The case I used was rather warm, too. I replaced the standard slot 1 fan with a larger version, but it still ran hot. Might try with a thermal gap filler and a different case at some point.
My 450 MHz PIII is pretty decent, the only reason the HP Vectra makes any noticeable fan noise is because the PSU one is a tad tired. Then again, it doesn't have a fan on the CPU, only a massively thick one on the front with some plastic ducting over the CPU heatsink fins.
