Reply 14 of 30, by 5u3
- Oldbie
wrote:How did they die? 😢 How long is the life expectancy of a V5, by the way? Do you overclock?
My first V5 died because of overlocking (> 200 MHz). Hey, I was young and needed the FPS! 😅
The second one overheated because of failing fans - those tiny little heatsinks don't provide significant cooling just by themselves.
So, when I got the third one, I wanted to keep on the safe side (and get rid of the fan noise), so I took some epoxy and made this:
Don't do this. Glueing rather heavy heatsinks directly onto a BGA-mounted chip without any further support will cause the connection between the chip and the board to fail eventually. Especially when the heatsinks are hanging upside down when the board is installed.
My current Voodoo card isn't modified yet, but those crappy little fans already sound as if they'll fail soon. I'll try big heatsinks again, but this time I'll include something that clamps them onto the board itself.
Gernerally the V5 cards are rather easily damaged. This is no surprise, as compared to a contemporary "normal" video card, the V5 has twice the amount of components and in-between connections to fail. Put them on a rather weedy, big PCB, and you're just asking for trouble.
If you ask me, we are lucky there still are enough working V5 cards to go around... 😉
wrote:Since V5 PCI is rarer than V5 AGP, isn't it possible to pull the VSA-100 chip off of a V5 AGP, then use it to replace the broken chip on the V5 PCI? I've never tried such thing before, but practically, how difficult it is to take off and solder back a GPU chip?
Since the chips are BGA, swapping the chips seems impossible. Well, on the net you can find some adventurous approaches involving toaster ovens, but that'll unlikely work on a big and complex card like the V5.
