Reply 140 of 288, by Predator99
computerguy08 wrote on 2021-04-01, 15:26:
I'm pretty sure this is a Zida 4DVS, not an MSI. […]
Predator99 wrote on 2021-04-01, 12:02:
#92 […]
Manufacturer/Identifier: MSI MS-4132 G ver. 1
Chipset: SiS 85C471/85C407
BIOS String: 40-07Z5-008031-00101111-121593-SIS471
http://www.win3x.org/uh19/motherboard/show/6881
40-07Z5-008031 - this further indicates my point
Copy&Paste error - fixed, thank you!
The board is very damaged, really ugly and goes straight to the bin...
Reply 141 of 288, by Deksor
It doesn't look that bad to me, it sure is dirty, but what's so bad about it ?
Reply 142 of 288, by Predator99
Yes, this dirt is really ugly. Looks like smoke but doesnt smell. Many small traces destroyed under the battery. Scratches mainly on the bottom side. This isnt worth the effort of cleaning and testing...
Reply 144 of 288, by Predator99
This looks very generic and it shouldnt be difficult to find a working one.
80286 BIOS image collection
#18 and #37 are very similar to your board.
Or try one of the images under #61, I would prefer MR-BIOS.
Also some other ICs seems to be missing, cant read the labels on your photo. At least the keyboard controller.
Reply 145 of 288, by Bela Breda
Predator99 wrote on 2021-04-24, 18:11:
This looks very generic and it shouldnt be difficult to find a working one. […]
Thank you very much. I will try one of them. Yes, I know some other chip is missing. Two 8259 and the keyboard controller. What do you think, will it work with a keyboard controller from an other 286 motherboard?
Reply 146 of 288, by pentiumspeed
This what you are missing:
BIOS firmware in high and low (odd and even) Phoenix firmware version will work.
pair of 8259 IC interrupt controllers. NEC is cooler and reliable.
and finally keyboard controller. Older one is preferred, which is little tricky.
Cheers,
Great Northern aka Canada.
Reply 149 of 288, by Horun
jheronimus wrote on 2021-05-15, 12:35:
I'm looking for a BIOS to this board, Biostar MB-1500/1575/1590PCT, also known as MBD-P90VP2 in Quantex computers. […]
The BIOS ID string is 2A5UMB01-00
I searched thru archive.org and found one reference to the board at Quantex website but Biostar and Bioteq do no list it at all (The 15xxTIC was listed but not the 15xxPCT), not even jumper settings.
When searching for the BIOS found references but no bios file leading me to believe it was on a non flashable EPROM instead of an EEPROM - OR - they never did a bios update.
http://web.archive.org/web/20010405005434/htt … useum_Index.htm
http://web.archive.org/web/20010223215901/htt … rt/support.html
http://web.archive.org/web/19991012153552/htt … com/mbdinfo.htm
http://web.archive.org/web/19990428000548/htt … .com/bbsqtx.htm
Reply 151 of 288, by Horun
Jim5589 wrote on 2021-05-14, 20:07:
Horun wrote on 2020-12-28, 01:54:
#74 Motherboard: Amptron DX9200 AKA PcChips M915i with Fake cache Chipset: UMC UM8881F + UM8886BF EPROM: AMD AM27C010 BIOS Strin […]
with Fake cache
EPROM: AMD AM27C010
BIOS String: 41-p400-001437-00101111-101094-486AVIP-H
BIOS label: AMI 486DX ISA BIOS 1993
BIOS Version: AMI 10/10/1995: 11-08-1995
CRC 32bit Checksum: 82A4E810
Note: this Fake Cache bios is not same as the M915i BIOS 9151108s floating around.
http://www.win3x.org/uh19/motherboard/show/579
http://www.win3x.org/uh19/motherboard/show/5944
Included the 9151108s BIOS
Sorry if this is a stupid question but I am learning still. I have ended up with one of these boards with the fake cache on it. I plan to remove the fake cache and put some real stuff on it along with the jumpers to configure it. If I do this can I then put the bios on the unit from the links you have posted to make it work properly ?
No not that I know of, that BIOS was written specific for that FAKE cache board model and version so it appears to have cache. You need the BIOS off one that has working cache. Cannot find the exact topic but there is a good discussion about adding cache and what bios to use where members tried different BIOS releases and which ones worked.
Reply 152 of 288, by Horun
Predator99 wrote on 2021-07-26, 21:27:
Re: 80486 BIOS image collection #98 […]
#98
Manufacturer/Identifier: Unknown ETEQ 80486
Chipset: ETEQ ET82C491, ET82C493 Chips & Technologies P82C206
BIOS/Version:
BIOS String:
This board (Unknown ETEQ 80486):
http://www.win3x.org/uh19/motherboard/show/5494
I got it without BIOS+KBD-controller. But it works with..:
- A433C-C/A450C-C, by J-Bond, found here
http://www.minuszerodegrees.net/at_clone_bios … _clone_bios.htm
- MRBIOS V018B401, found here:
How about a MR-BIOS ROM file repository?
Both need to be split in HI/LO, attached in file.
Wow 16-30pin simm sockets ! Nice and has cache too. Closest I seen personally is a Vtech/PcPartner 486 board with 12-30 pin simm sockets and cache.
Thanks !
Reply 153 of 288, by NiPPonD3nZ0
I'm looking for a BIOS for a newer, but uncommon board! Well, the board itself is kinda generic, but the BIOS on a variant from Creative Labs (Yes, that Creative, from the SoundBlaster cards) is impossible to find!
The board I want a BIOS from is a Creative Labs M000, basically a Shuttle HOT-637 but with a BIOS customized by Creative!
Anyone has one that is willing to dump it?
Reply 154 of 288, by Predator99
Horun wrote on 2021-07-27, 01:06:
#98
BIOS/Version:
BIOS String:
Thanks !
Thanks, indeed a very nice board from a scrap lot and I am happy its running again! It reports some problems with the cache but I assume one IC is still missing there.
Reply 155 of 288, by Horun
BreakPoint wrote on 2021-08-02, 12:22:
#: 71 Manufacturer/Identifier: KT216WB 5/HI REV 2 Chipset: Winbond W83C20x BIOS/Version: - None: Copied from dead board […]
BIOS/Version: -
Nice ! Bummer the sea of green corrosion all over the poor old board.
Mingohp wrote on 2021-09-26, 15:28:
Hello. […]
Hello.
My name is José Domingo, I live in the Canary Islands.
I recently purchased an Acer 915V 286. He displayed inconsistent characters at startup. But I was still able to launch it and run a game from the flogged disk. I thought the problem with inconsistent characters was because of the BIOS. Today I removed the eprom to back up with my MINIPRO TL866. My surprise was that my MINIPRO does not read them, but worse was that now my PC does not start.
Would anyone be so kind as to provide me with a copy of the high and low bios?
I would be very grateful for any help.
Best regards.
You accidentally posted in wrong place, this Discussion area is for questions - answers.
Reply 156 of 288, by Mingohp
Sorry. I'll post here, is that okay?
Horun wrote on 2021-09-26, 15:52:
Nice ! Bummer the sea of green corrosion all over the poor old board. […]
BIOS/Version: -
Hello. […]
Hello.
Best regards.
Reply 157 of 288, by Mingohp
Hello.
I know that a member of this forum has an ACER 915P and uses the same BIOS, RETROSPECTOR78.
Best regards.
Reply 159 of 288, by BreakPoint
Need help with board identification.
    788.59 KiB
My CPU collection - Looking for hardware in Ukraine - Ukraine vintage PC forum
