Reply 140 of 1282, by shock__
- Oldbie
georgel wrote on 2022-09-11, 02:31:carlostex wrote on 2022-09-10, 22:55:Not to mention the actual money needed to acquire each separate.
Yep, a crystal based sound card costs about $30 on fleabay, and with the release of ARGUS PCBs the Gravis clone is about $40...
As the main ARGUS-person I strongly endorse this card, it's very obvious that it's a product of passion. It's made by 3 persons which had large, positive influence on the ARGUS project - they know what they're doing.
If you have a cheaper way of achieving the same result -> good for you. Doesn't make this card any worse, nor does it save you an ISA slot.
Current Project: new GUS PnP compatible soundcard
[Z?]
