serial mouse not detected on a 386 motherboard
Reply 140 of 144, by weedeewee
rasz_pl wrote on 2023-07-01, 06:30:
one picture of scope screen would solve it immediately 😀
depending on the scope... screen & settings 😉
Do not ask Why !
Reply 141 of 144, by feipoa
I've experienced the same issue with a cold joint in the past - lightly tapping it with a probe made the cold joint temporarily disappear.
As motherboards get older, I'm finding myself reflowing parts more and more.
Reply 142 of 144, by rasz_pl
pshipkov wrote on 2023-07-01, 06:50:
It shows on the oscilloscope screen.
picture of TX signal would show mangled logic levels, turning on serial decoder would reveal its a bad signal
With both 1488/89 level translators missing negative supply there was a considerable chance of receiver interpreting bad input correctly resulting in working loopback test, now that one would be fun to debug with most people arguing physical transmission is clearly working so no need to look at the signal 😀
glad its fixed
https://github.com/raszpl/FIC-486-GAC-2-Cache-Module for AT&T Globalyst
https://github.com/raszpl/386RC-16 memory board
https://github.com/raszpl/440BX Reference Design adapted to Kicad
https://github.com/raszpl/Zenith_ZBIOS MFM-300 Monitor
Reply 143 of 144, by Horun
Glad you found the issue and was an easy fix !
Reply 144 of 144, by pentiumspeed
pshipkov wrote on 2023-07-01, 02:20:
Success ! It was the -12V line. A rail somewhere flaking on and off frequently from even gentle touches of the components. So, a […]
Success !
So, apparently when i measure the -12V is mostly ok. So even for a moment it shows 0V i assume it is me not holding the probes right and pushing/tweaking them which brings the voltage back.
Pulled a wire on the back to pin B7 and that was it.
Thank you very much guys and especially to you @Deunan for prompting me to inspect this more carefully.
Command ports and how they function was never of big interest to me, but the information in this thread was a bonus to the fix itself.
Yay!! Good work!
Cheers,
Great Northern aka Canada.
