DOSBox Icon
Reply 140 of 333, by covox_account_sans.ttf
A quick remaster for the traditionalists in the audience. Apologies for the eye-bleeding appearance of the beige, that was the closest I could get to an agreeable colour. (I promise it looks a lot less searing on a white background)
Slightly Changed Master (SVG/PNG)
Reply 144 of 333, by doomer
It looks great. 😀
But I have a suggestion. Why don't you use "c" as the drive letter instead? I don't know about the others but I've always associated dos with the c:\> prompt. Even in dosbox I have the autoexec mount settings and the "c:" command after that. I definitely think that c:\> is in the spirit of the dos era. 😀
Reply 145 of 333, by nsmcovox
C:\> is a bit more nostalgic, but some people reckon that the similarity with the windows command prompt icon would cause a bit of a kerfuffle.
Ah, one more can't hurt...
Beige III Master (SVG/PNG)
dosbox_beigeIII32.pngdosbox_beigeIII64.pngdosbox_beigeIII128.pngdosbox_beigeIII256.png
(I still reckon the Z:\> looks classier 😜)
Reply 148 of 333, by augnober
I've got one suggestion which you may already have planned, but I'll mention it anyway..
For the smaller versions of the icons, it's worthwhile to redraw/touch-up the "Z:\>" (or C:\>) to make it brighter and clearer. Scaling down using whatever scaling you're using is dimming and blurring it, so it they don't look as good as the large one. The smallest versions will be the most important in the end (common icon size).
Reply 151 of 333, by DosFreak
I still prefer ChaosFish icon as compared to the framed "C" or "Z" icons, due simply to the fact that Chaos's are more uniform in color and more distinct.
Make your games work offline
Reply 154 of 333, by ih8registrations
BTW, altered the 32x32 so "DOS" isn't obscured by the link arrow in windows.
    1.58 KiB
Reply 155 of 333, by ih8registrations
A choice of 16x16 icons.
    1.08 KiB
    1.09 KiB
Reply 157 of 333, by ChaosFish
Don't expect anything else from me 😀
My icon is done (last version here), so use it if you will. Altough I'll be willing to make improvements if anybody has any constructive ideas. For the other awesome icon artists - may the best icon win the way to the official build!
