Reply 14500 of 58933, by James-F
But, I just noticed the pictures of the card are EXACTLY the same pictures from this link: http://www.flaterco.com/kb/audio/ISA/index.html
In the link above it says the card was broken on arrival.
I am not talking about similar, is is the very same card.
Looks at the green sticker, soldering on oscillators, jumper orientation, component slants, two red marks on top left corner. 😐 😐
The seller I bought it from had another exact same CT1740 card on August 25th.
I already contacted the seller to make sure he actually ships the pictured card, and it is tested and working like ebay auction said.
EDIT:
I contacted Dave from flaterco.com and indeed this is the very same card he bought from the same seller in July 2016.
The seller sunking tries to sell this defective card over and over again each month.
Please do not buy THIS particular CT1740 from sunking because it is defective (no sound on one PCM channel) and has been returned countless times.
Reply 14501 of 58933, by Api
Ahhh.. twenty years late but who cares. Now just have to hope it works.
EDIT: OK it works, played GLQuake and 3DFX patched Descent.
IntelSE440BX-2 256MB PII-300 Rage128 Voodoo2 SLI Vortex2 SB32 Win98SE
Asus A7N8X-E Deluxe 1GB Athlon XP2400+/XP3000+ Radeon 9600XT
FIC PT-2000 P120 Matrox Millennium 2MB Orchid Righteous 3d
Reply 14502 of 58933, by FuzzyLogic
Nice! That was the 3dfx Voodoo I first wanted, but then I learned about the Canopus Pure 3D 6MB and I drooled. I never got either card back then. And to this day I have never owned a 3dfx card. I need to get the Canopus Pure 3D... my life will not be fulfilled if I don't.
Reply 14503 of 58933, by rkrenicki
There are a couple of them on eBay in box. They are not cheap however 🙁.
Reply 14504 of 58933, by Ariakos
Yamaha Audician 32 Plus (ISA SB clone) 10€
GeForce 2 MX200 32MB (AGP 4x) 3€
Audician goes to my slim case 386 SX-20 as an all-around sound card. I'm planning to use the card itself for Sound Blaster FM synth and connect Roland MT-32 through the card's game port for MIDI (maybe I'll add SoftMPU if I feel like I need the intelligent mode). GF2 I bought just because I got it for cheap (and I thought it might have worked in my current P2-450 build but sadly no: motherboard had only AGP 2x slot).
Reply 14505 of 58933, by melbar
Your Geforce 2 MX is compatible with an AGP 2x slot.
You can see the two notches at this card.
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
Reply 14506 of 58933, by brostenen
Congrats. To me, the clicking relay's are what makes the Orchid a special card.
I am on my third card now, since the late 90's. Never owned more than one at time though.
And none of them has given me any issues. I have had other V1, only they have felt "cheaper".
Reply 14507 of 58933, by Ariakos
It should be compatible, yes. But my PC's monitor remains blank when I tried it. Same thing happened with GF4 MX400 I have (both are AGP 4x). My motherboard is based on Intel 440BX, does that have something to do with my troubles?
Reply 14508 of 58933, by TheMobRules
I have used a GeForce2 MX card on an Intel SE440BX-2 board without issues so I don't think the chipset is the problem.
Reply 14509 of 58933, by Ariakos
Truth be told I don't know where the trouble is. It could be that both my GeForce MX cards are defective. Or the motherboard I try to apply to them has some AGP issues (the original Matrox Millenium G200 AGP 2x it has now works just fine). If I had another AGP motherboard or more AGP cards at the hand I could experiment more. I just got tired of the whole ordeal and installed a Voodoo 2 card in PCI slot to take over the 3D from the Matrox. Now the system works ok.
But anyway, enough of this derail. Others probably want to hear about recent buys more than my current GPU problems... 😵
Reply 14510 of 58933, by candle_86
A Supermicro X7DVA-8 771 Motherboard with Xeon E5150's socketed in both sockets. Need to find a heatsink
The attachment WP_20161101_15_55_12_Pro[1].jpg is no longer available
Reply 14511 of 58933, by luckybob
@candle_86
use these: http://www.newegg.com/Product/Product.aspx?It … N82E16835114056
The processors are a bit close together for large single heatsinks, the ones I linked are VERY effective. The boards PWM will keep them quiet, but if the temp goes up the can scream. I use them for my similar board (mine is micro-atx)
Reply 14512 of 58933, by ElementalChaos
...Oh boy. So that's what an impulse buy feels like. $37.76 shipped. All untested. This could either be an incredible haul or a terrible mistake...
Yes, I'm aware the two mobos with barrel batteries are most likely toast. But I already have a working 486 VLB board, and the other two appear to have a coin cell and a wired battery pack (whatever you call those things) respectively.
Pluto, the maxed out Dell Dimension 4100: Pentium III 1400S | 256MB | GeForce4 Ti4200 + Voodoo4 4500 | SB Live! 5.1
Charon, the DOS and early Windows time machine: K6-III+ 600 | 256MB | TNT2 Ultra + Voodoo3 2000 | Audician 32 Plus
Reply 14513 of 58933, by stamasd
It shouldn't. I have a GF4 Ti4200 in a 440BX motherboard, it's 4X and works nicely.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 14514 of 58933, by Artex
ElementalChaos wrote:
..or a terrible mistake...
Not for ~$38 bux!
Reply 14515 of 58933, by Jade Falcon
Rank BANNED
BANNED
If you do not want ether of those 2 barrel batteries motherboards send me a pm. Working or not.
Reply 14516 of 58933, by Tetrium
...Oh boy. So that's what an impulse buy feels like. $37.76 shipped. All untested. This could either be an incredible haul or a […]
I spot an S3 VLB card made by Diamond (the one with the blue sticker on the BIOS chip and its logo in the top left corner), a Cirrus Logic VLB card, ISA io card (single IDE), ISA NIC without bracket, some SDRAM, couple modems, the AGP graphics card looks to be some GFMX I think, Ati AGP card (probably Rage 3D or something, probably 8MB), couple cards I can't really see what they are and 3 Socket 3 boards which have cache chips that can be removed and placed into another board (they look like ordinary 32kb cache chips), Socket 7 board which seems to have 430VX chipset or so.
Good haul!
edit: The Ati AGP card looks like this one (sorry, I don't remember how to create thumbnails, the pic is a bit large 😊 ).
edit2: The GFMX looks to be a GF4MX card like this one http://www.gpureview.com/database/images/card … 4-mx-440-8x.jpg
My retro rigs (old topic)
Report spammers here!
Reply 14517 of 58933, by kithylin
luckybob wrote:
@candle_86
Just a note, make sure you read the specs there. These fans are -LOUD-, specs are right there on the page. Rated for 51db @ 100%. They also use a unique fan size of 77mm and I've had these before... trust me.. if you want to swap the fan for another, you'll never find another fan anywhere that's 77mm.
Reply 14518 of 58933, by luckybob
Its not an issue. My fans are near silent 90% of the time, and are adjustable via bios settings.
Reply 14519 of 58933, by brostenen
These two just arrived.....
Looking forward to test them out. Eighter tonight or I will have to wait until monday.
One of them looks like a wavetable card and the other looks like OPL4-wavetable.
I sold a pack with various hardware a while ago (helped one get into this hobby)
and I bought them for the money I got.
The attachment Lydkort-01.jpg is no longer available
Both cards at display
The attachment Lydkort-02.jpg is no longer available
Closer look of the first card
The attachment Lydkort-03.jpg is no longer available
Closer look at the second card
