VOGONS Driver Library
Reply 1461 of 1477, by Horun
You cannot change a file once uploaded, you can only edit the picture, description, and category. Include in the zip any texts, docs or pictures . Zip it up with 7zip or winzip.
Include a picture of the device or the disks if possible (only need be 800x800 pixels +/- .JPG) and Give a small description...
You can look at some of the other library posts to see what others have done....That is all I can think of.
Reply 1462 of 1477, by Horun
Uploaded my collection of Reveal sound card drivers. There are a few bad files but also some work arounds....http://www.vogonsdrivers.com/getfile.php?file … 3&menustate=0,0
Due to recent circumstances will be trying to catch up and upload a bunch more..as time allows..
Reply 1463 of 1477, by vetz
Horun wrote on 2024-03-26, 02:04:
Its a feature I've requested before. If you have a driver compilation which needs updating and you have good reasons, then Squallstrife can do it behind the scenes, atleast he did for me for the PowerVR driver compilation.
Reply 1464 of 1477, by myne
So, I got bored.
Installed 3.11 on Vmware, found out that there's a patching tool for the SVGA driver, figured that was a bit of a pain for your average pleb, bundled the patched driver with an inf file so your average joe can install it like a normal driver.
The main feature is simply that because it is renamed, and has a different name in the inf which clearly defines it as a vmware patched driver, it doesn't interfere with the standard drivers if for whatever reason that is an issue.
I... don't think a patched standard driver would be considered naughty, so here it is.
One thing I don't understand is that it works perfectly WITHOUT network, but goes haywire when the network is enabled.
I didn't make the patch, so I have no idea why this could be except possibly resource conflicts. I'll see if I can figure it out, but for now you've been warned.
Kinda curious how many people care if any.
    Win311 VMWARE SVGA Patched.zip
    41.86 KiB
    14 downloads
    Win311 VMWARE SVGA PATCHED
Things I built:
Mechwarrior 2 installer for Windows 10/11 Re: A comprehensive guide to install and play MechWarrior 2 on new versions on Windows.
Dos+Windows 3.11 auto-install iso template (for vmware)
Reply 1465 of 1477, by myne
Here's another couple of utils that would be useful to add.
CD-Open, cd-close (msdos)
Shamelessly created from instructions here:
https://groups.google.com/g/alt.msdos.batch/c … 1WuHhR38A?pli=1
DONALD G. DAVIS wrote:
> >> I wrote a tiny DOS program that will open/close CD-ROM trays by
> >> drive letter, from the command line or batch file. It's fully
> >> functional under MS-DOS and Win9x, but only the "open" function works
> >> under NT/2000/ XP. It's not on Internet sites, but I'll e-mail copies
> >> on request. A Web search will locate several other similar programs.
Here is a (similar?) program (2 actually). I have only one
CD-ROM drive so I don't know how this will work with multiple
drives.
:: cd-opcl.bat
@echo off
if "%1"=="1" goto close
if "%1"=="0" goto open
echo. Syntax: %0 0³1
echo. opens or closes cd-rom tray
echo. 0 (zero) to open, 1 (one) to close
goto end
:open cdtray
echo:`h}aXP5y`P]4nP_XW(F4(F6(F=(FF)FH(FL(Fe(FR0FTs*}`A?+,>%temp%.\cd-open.com
echo:fkOU):G*@Crv,*t$HU[rlf~#IubfRfXf(V#fj}fX4{PY$@fPfZsZ$:K68$.>>%temp%.\cd-open.com
echo:.T]6KRw'RmSf/*VtTZ$K+}n\I/~{R'K*X{/wW$Q3;[5:Jl.oh_fRW'[g9'e>>%temp%.\cd-open.com
echo:0sum5FrT_0rLen$'?qN$$$$$$$$$$$$$$$F7{{/t$fJb$$/)e#>>%temp%.\cd-open.com
for %%c in (call del) do %%c %temp%.\cd-open.com
goto end
:close cdtray
echo:`h}aXP5y`P]4nP_XW(F4(F6(F=(FF)FH(FL(Fe(FR0FTs*}`A?+,>%temp%.\cd-close.com
echo:fkOU):G*@Crv,*t$HU[rlf~#IubfRfXf(V#fj}fX4{PY$@fPfZsZ$:K68$.>>%temp%.\cd-close.com
echo:.T]6KRw'RmSf/*VtTZ$K+}n\I/~{R'K*X{/wW$Q3;[5:Jl.oh_fRW'[g9'e>>%temp%.\cd-close.com
echo:0sum5FrT_0rLen$'?qN$$$$$$$$$$$$$$$F8SC4t$fJb$$/)e#>>%temp%.\cd-close.com
for %%c in (call del) do %%c %temp%.\cd-close.com
:end
    CDopenClose.zip
    632 Bytes
    14 downloads
Things I built:
Reply 1466 of 1477, by SquallStrife
vetz wrote on 2024-04-02, 07:08:
^^^ This is the best way to do it, presently.
Also, regarding viruses/malware/trojans/etc in the files in the archive: if anybody wishes to bring these to my attention, please do.
However:
1. It's better to post the information in this thread, where multiple people can see and potentially validate the report. Most "infections" I've investigated have been false-positives.
2. At the very least, please include: A link to the download on the site, the name of the infected file within the ZIP/RAR/etc if applicable, and the name of the alleged virus.
Reply 1467 of 1477, by Revolter
henk717 wrote on 2021-04-15, 16:05:
I have a driver to contribute, I have found the official ESS Solo-1 driver online for Windows 3.11 but unfortunately the package […]
I have a driver to contribute, I have found the official ESS Solo-1 driver online for Windows 3.11 but unfortunately the package was awful (wrong folders, random autoexec.bat file) and the installer was broken despite coming from the official archived website.
Attached is a .zip file I put together that contains the official ESS Solo driver, but with an older installer exe taken from the ISA ESS AudioDrive and everything restored to the proper locations. This will allow the driver to install if you first load the ESS Solo dos driver. It provides WAVE and MPU support to Windows 3.11.
I have also included the ESS AudioRack that was part of the ESS AudioDrive driver bundle I took the install exe from.
This should allow other ESS Solo-1 owners to more easily use this card on Windows 3.11 as I am not aware of any other working install packages for this card that support 3.11.
The archive.org link can be found here : https://archive.org/details/essolo-311
Hi,
Thank you for the upload and the general idea on how to fix the ESS Solo-1 (ES1938) Windows 3.1x driver, but, sadly, the .EXE files from another driver break MIDI and FM ("The current MIDI Mapper setup refers to a MIDI device that is not installed on the system. Use MIDI Mapper to edit the setup.").
In order to fix the original factory driver for good, you simply have to move 3 of its own files (ESSSETUP.EXE, ESSLANG.US and ESSSOFT.INI) up one folder, and rename the folder itself to "ESSSET".
When using a MIDI daughterboard, make sure AuxB is enabled in AudioRack, and also that your MIDI Mapper configuration points to ESS AudioDrive MIDI Port Output and not ESS AudioDrive MIDI (otherwise you'll only hear ESFM), like this:
42.76 KiB
    ESS Solo-1 (ES1938) Win3.1x Driver.zip
    214.5 KiB
    2 downloads
    Official ESS Solo-1 driver with fixed installer and working MIDI & FM
Celeron 800@1066, 512MB, GeForce2 MX AGP/GeForce 8400GS PCI, ES1938S/Dreamblaster S2, DOS 6.22/Windows 3.11/Windows ME/Windows 2000
Reply 1468 of 1477, by douglar
Revolter wrote on 2024-05-16, 14:36:
I put it here: http://www.vogonsdrivers.com/getfile.php?fileid=2175
Reply 1469 of 1477, by Revolter
douglar wrote on 2024-05-16, 22:34:
Appreciate it, mate!
Reply 1470 of 1477, by porksmuggler
I felt like messing around with some other drivers than the recommended Audigy ones for a SB0220, but the download hit for a trojan. Are the uploads run through scans? VirusTotal even? Also is there a reason the site isn't https?
Here's a link to the fileI downloaded, http://vogonsdrivers.com/getfile.php?fileid=809&menustate=0
Reply 1471 of 1477, by DosFreak
See Re: VOGONS Driver Library
Replace the http with https and it should work. Keep in mind that there likely isn't a redirect since the site is for old systems.
Make your games work offline
Reply 1473 of 1477, by Horun
What AV program and what Trojan ? I scanned the file with Windows Defender with newest update, and Super Anti Spyware on my PC and found nothing then sent it to Virus Total and only one app Vir.IT found a trojan called Trojan.Win32.Click.CQE....
35 other well known AV apps found nothing so it must be a false positive.
https://www.virustotal.com/gui/file/bfd7232cf … e2e7b173f593d3a
Note about Defender: https://www.microsoft.com/en-us/wdsi/threats/ … tId=-2147458352
and appears Vir.IT does false positives like here: https://www.virustotal.com/gui/file/26a644c19 … 958119a0aaff83a
I will rescan on the other pc but think it has nothing in it....nothing found local.
added: Here is the same but as original ISO : https://archive.org/details/creativesoundblas … d_2201ml0000117
according to the disk.id file...
Reply 1474 of 1477, by porksmuggler
Sorry, I didn't include the details. It was Defender, yesterday evening, Trojan:Win32/Vigorf.A , which is a severe threat level. This is on the linked SB0220.7z
Thanks for the ISO though, I'll check that out instead.
Reply 1475 of 1477, by kingcake
I would update the Defender definitions and try again. Defender sometimes gets a bad update that causes false positives then MS pushes a new definition update that fixes it. Has happened many times. One time they broke it so bad it quarantined Windows System files that prevented Windows from booting.
Reply 1476 of 1477, by Horun
Agree ! Update the Definitions.edit: I scanned it with Defender and the newest Definitions created 5/18/2024 in Win10 and 5/16/2024 in Win7 Pro and it did not find anything.
