Reply 15160 of 57716, by stamasd
The socket8 motherboard is here. Tested with CPU and RAM, boots fine. I decided to skip the IDE stuff and go directly for SCSI. Ordered a few drives (some nice 18GB 10K ones) but they'll take a few days to get here.
NT4 or W2K?
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 15161 of 57716, by luckybob
nt4 for 200mhz. 2000 if you use overdrives.
Reply 15162 of 57716, by stamasd
Yeah I was leaning towards NT4 also. And dual boot with 98 for LOLs.
Too bad it's a single CPU board only. I have a nice pair of SL22Z waiting for a dual board.
Any advantage to using an AHA29160N over a 2940UW? Probably not in this machine, but I thought I'd ask anyway.
I/O, I/O,
I/O, I/O
Reply 15163 of 57716, by mrau
theoretically a controller with higher max speed will give you benefits from the moment you can saturate the slower one - cant a ppro200 machine pull more than 40mb/s from scsi?
Reply 15164 of 57716, by yawetaG
torindkflt wrote:
My brother also gave me a 1GHz eMac with OS X 10.4 on it. Works mostly ok, but has a couple weird problems with the screen that are beyond my ability to repair if it can even be repaired (faint diagonal lines going across the screen every inch or so, and the screen just goes to a flickering gray box when it tries to go to sleep).
It could be something as simple as a badly connected cable inside the Mac (although eMacs also have problems with bad caps - sleep issues may be related to that, but should affect more than only the screen).
Reply 15165 of 57716, by Nestel
Hi. I Don't know if to call it a retro but its a HDD from Jan 2009.
Reply 15166 of 57716, by MMaximus
torindkflt wrote:
Was given a couple NOS WYSE keyboards by a friend.
These look great. The first one has actually 16 F-keys as opposed to the standard 12 - I've never seen this layout before.
Hard Disk Sounds
Reply 15167 of 57716, by Rawrl
Well, LVD is a lot less temperamental than single-ended SCSI. Regardless how much the PPro can pull across the bus, you should see some benefit from the 29160, assuming an LVD cable and at least Ultra-2 drives.
Reply 15168 of 57716, by Carlos S. M.
Got this Radeon 9250 PCI for an AGPless dual P3-S system
Reply 15169 of 57716, by havli
Nice... but 128bit DDR would be even better.
Reply 15170 of 57716, by brostenen
Just recieved some memory modules.
- 4 pieces of 64Kx8-15ns (UM61512AK-15)
- 2 pieces of 512kb ram, 1mb in total for PCI vga cards (Trio64/Virge325 and so on)
They were really cheap, so I have waited a long time for them to arive.
Reply 15171 of 57716, by dogchainx
So I got this bad boy...........Brand new IN BOX, MINT condition, NEVER USED. 😎
Even comes with extra RAM already installed for 1MB of RAM.
Wr1vsxim.jpg?1
386DX-40MHz-8MB-540MB+428MB+Speedstar64@2MB+SoundBlaster Pro+MT-32/MKII
486DX2-66Mhz-16MB-4.3GB+SpeedStar64 VLB DRAM 2MB+AWE32/SB16+SCB-55
MY BLOG RETRO PC BLOG: https://bitbyted.wordpress.com/
Reply 15172 of 57716, by oeuvre
😮 what a find! Where did you get it?
Reply 15173 of 57716, by dogchainx
I'm not at liberty to say at this time, as I'm still in contact with the individual. Maybe a few years down the road I'll be able to tell the tale. For now, lets just say that this WILL go down in GUS history as one of the most important finds of the century and I'll have photos to prove it.
This thing is so freak'n rare, especially with it being in box MINT and VIRGIN.
Reply 15174 of 57716, by keenmaster486
What... what is that?
World's foremost 486 enjoyer.
Reply 15175 of 57716, by brostenen
I won't be able to top that gravis compatible card. Ever.... Awesomme find.
I can only think of one reason that it is rare.
The last one from the production line, or the very first one.
Reply 15176 of 57716, by yawetaG
Could be a sales or review sample for a product that never reached mass-released retail (standard ViperMax has only 512 Kb RAM according to Wikipedia, so for it to come with 1 MB right in a sealed box - updated version that was not actually sold?). In which case you'd be looking at a total production of only a few...
Reply 15177 of 57716, by Ariakos
Christmas came a tad earlier to my home... 😁
Reply 15178 of 57716, by oeuvre
Found a Gateway 2000 Anykey keyboard for less than $30 shipped on eBay. Pounced on it. Has a sticky ESC key and the seller says he can't seem to program keys correctly. Claims everything else works fine. Thinking it just needs the macros to be reset.
Reply 15179 of 57716, by Carlos S. M.
Got all of this for 10 €
An old Fujitsu SCAELO with a BIOSTAR M6VCG, Pentium III 866, 256 MB RAM, nVidia TNT2 M64 32 MB, VIA Firewire card, AMR Modem, Ovislink network card with a Tiger 320 chip (?), HDD is missing
Two IBM Thinkpad A21ms, both Pentium III (can be 700, 750 or 800 MHz), one has 64 MB RAM and no HDD, the other has 128 MB RAM and 10 GB HDD
Need to test them
