Reply 15380 of 27691, by xjas
- l33t
Spent a fair bit of time setting up this cute Toshiba NB555D to do... well, basically what you see in the picture. I inherited it (from my mum) with a "big" install of Linux Mint 18.3 with the Cinnamon desktop, but that was pretty overbearing for this little 9-year-old netbook. I decided to try PeppermintOS (not related to the 'other' Mint), which is based on LXDE and tries to be lightweight while still being full-featured & useable. (More importantly, it uses Ubuntu/Debian package repos and has Nemo for a file manager. Big pluses in my book.) It goes OK.
Floppy disk for scale...
This thing "looks" pretty good for its era on paper - it has an AMD APU with a Radeon HD6250, it's been upgraded to 4GB of RAM and it even has a 500GB HDD (yes, I know an SSD would be better.) It also has SURPRISINGLY good Harman/Kardon speakers which is why I want to use it for music, tons of I/O (3 USB ports, HDMI, VGA, wired ethernet, mic/line-in) and really nice build quality. The problem is this is the low-rent version, with a single-core, single-thread AMD C-30 that runs at 1.2GHz. It is glacially slow and really gimps the machine. Even back in 2011 that was pretty hopeless. You could get an uprated model with a dual-core version of the same CPU (AMD C-50 or C-60) which would be a ton better, but my mum got this through her work back then, and of course they issued everyone the absolute base model. She chucked it in a drawer and barely used it. I imagine most of these got sold like this one, with the absolute cheapest possible spec, and then retired early because of that. What a waste.
(The 1024x600 screen doesn't help either, a lot of software just plain doesn't fit in that. Fortunately most Linux distros have a way to drag windows around without needing to keep the title bar on-screen.)
Anyway, I want it to run Sunvox, Deflemask, Schism Tracker, etc., which it does fine, and it can even handle moderate stuff under DOSBox, but forget about getting any performance out of web browsing with it. I'd love to use it to monitor Twitch chat, but it takes a full minute to load the site (once it's loaded, the chat itself goes OK as long as you stop the stream preview) and trying to do anything once there is agonizing. Even installing packages with APT or decompressing things tends to peg the CPU at 100%.
I'd bet anything this CPU still has the second core on the die, since it's basically the same thing as the C-50/C-60. If there's a way to unlock it Phenom II style I'd love to know about it. Can't find much online though. As it is, I'm looking around for a replacement mainboard with the dual-core option. If only it had a socket...
Why can't laptop makers bring this form factor back? Stuff a modern quad-core APU in, ditch the 2.5" SATA bay for NVME, ditch the HDMI for mini-Displayport, put in a better screen that eliminates the bezels, and keep everything else exactly the same. People would be lining up around the block for them. I would!
