Reply 1560 of 3358, by robertmo3
at first look nothing has changed in tr 😉
Reply 1561 of 3358, by sharangad
robertmo3 wrote on 2024-05-18, 07:11:
That's in the mansion will test it.
My testing so far has been in actual gameplay.
https://patreon.com/Rready
Reply 1563 of 3358, by robertmo3
new game
Reply 1566 of 3358, by sharangad
sharangad wrote on 2024-05-18, 08:19:
robertmo3 wrote on 2024-05-18, 08:13:
new game
As does the fist level.
I think your intel CPU doesn't like my custom bitset.
I'll switch back to std::set to see if it fixes it.
Reply 1567 of 3358, by robertmo3
maybe check it on your intel machines first
Reply 1569 of 3358, by sharangad
robertmo3 wrote on 2024-05-18, 08:35:
I've so far only tested CR on my intel machines and 2 of them crash on the second frame. WIll try now and the other one is being used.
Reply 1570 of 3358, by robertmo3
doesn't change anything
i use default dosbox.conf
and default Rendition.cfg
Reply 1572 of 3358, by sharangad
robertmo3 wrote on 2024-05-18, 08:45:
Can you zap teh dosbox folder and re-create it? With the binaries.
Also does the last known good version still work?
Also does software rendering still work?
Reply 1573 of 3358, by robertmo3
12 is still fine
13, 15, 18 have problems
same in win8.1 and win11
same with nvidia and integrated one
my guess is maybe higher cpu requirements makes game corrupt in the loading process, cause when i go to the swimming pool only textures are the ones of water surface and larra, rest is completely black
Reply 1574 of 3358, by sharangad
robertmo3 wrote on 2024-05-18, 09:18:
12 is still fine 13, 15, 18 have problems same in win8.1 and win11 same with nvidia and integrated one […]
12 is still fine
Ah ok. Hang on I've got just the thing for you. It'll be a bit slower, until I optimise it.
Reply 1576 of 3358, by robertmo3
doesn't make difference
Reply 1577 of 3358, by robertmo3
it looks hot thread attracted spambots 😉
Reply 1578 of 3358, by sharangad
robertmo3 wrote on 2024-05-18, 09:33:
With the last version use this.
Also try other priorities like higher,normal and higher, higher.
I did tweak memwrites earlier.
