Reply 15640 of 27644, by EvieSigma
Did some boring maintenance stuff. Updated the BIOS on my Packard Bell, tried to test out a Quantum Bigfoot drive that proved to be at least partially functional but also very annoying, and installed a Zip 100 drive in my Gateway G6-200.
Reply 15641 of 27644, by xjas
computerguy08 wrote on 2020-05-28, 07:51:
I stripped this 386 motherboard for spare parts.
No 386 boards were harmed for this photo, the battery leaked near the CPU and ruined the board.
How did you strip everything off so cleanly? I have a parts board I wanted to harvest the PCI slots & chip sockets (BIOS, etc.) from, but the idea of going at that with my hand solder sucker & wick is less than appealing.
Reply 15642 of 27644, by SodaSuccubus
Making CD Images out of the GOG games i bought that come with one.
So do you guys bother to patch games on DOS systems, or do you just install them off the disk and leave it at that? I find myself getting a bit anxious over un-patched games ^^;
But then again, im also lazy, and don't feel like taking out a CF card just to download a patch for every single game i own X)
I guess i cooouuuldddd just move the entire fully patched gog game onto the card instead of installing of disk but.....CDs! Man!
..atleast if it was a game that came on CD in the firstplace 😁
Reply 15643 of 27644, by brian105
Tried to get a BIOS image from my stupid 5284. UniFlash only got the first 128kb from it even though it's 256kb, and flashROM says no EEPROM available. No idea how the heck I can extract it without a SPI programmer.
Presario 5284: K6-2+ 550 ACZ @ 600 2v, 256MB PC133, GeForce4 MX 440SE 64MB, MVP3, Maxtor SATA/150 PCI card, 16GB Sandisk U100 SATA SSD
2007 Desktop: Athlon 64 X2 6000+, Asus M2v-MX SE, Foxconn 7950GT 512mb, 4GB DDR2 800, Audigy 2 ZS, WinME/XP
Reply 15644 of 27644, by Joseph_Joestar
SodaSuccubus wrote on 2020-05-31, 05:01:
Depends on the game, but usually yes. Patches sometimes offer significant improvements.
For example, games like the first Command & Conquer have some important bug fixes for the single player campaign, and I remember downloading that patch on my 14.400 modem back in the day. The original Quake offers much better performance with patch 1.08. Crusader No Remorse has a patch which adds native support for Ensoniq and GUS cards. And so on.
Reply 15645 of 27644, by xcomcmdr
I always patch them. I lived through the nineties. It taught me that most games come out with crashing bugs, save-corrupting bugs, compatiblity bugs, how-did-this-pass-QA bugs and so on. A trend that did not stop at all today.
Also, there were a lot of times patches to enable 3DFX compatibility, which is always a worthy addition.
Reply 15646 of 27644, by evasive
brian105 wrote on 2020-05-31, 05:06:
Presario 5284?
ftp://ftp.hp.com/pub/softpaq/sp11501-12000/sp11599.exe
Reply 15647 of 27644, by computerguy08
xjas wrote on 2020-05-31, 01:25:
A heatgun and some sharp pliers 😀
It took no more than 20 minutes for the entire board.
Reply 15649 of 27644, by RetroLizard
Played Descent II for the first time today, and wow, is it good. Wasn't able to hear the potentially rocking soundtrack though, likely because I was using a USB CD-ROM drive that the game didn't like.
Reply 15650 of 27644, by xcomcmdr
I used D2-XL to play it ( http://www.descent2.de/ ) which brings modern looks and the ability to read music from the local storage instead of the CD.
D2 XL looks very nice and plays better.
Even if after a while I missed the retro looks and the whole DOS experience so I went back to DOSBox. I'm weird.
Reply 15652 of 27644, by Mister Xiado
Spent most of the day making more Windows 95 icons, then running into a roadblock. I was trying to determine if I could backport more user directories into Win9X, such as Pictures, Videos, and Music, and stuff them into the My Computer set, but then I was put into a... very, very bad mood that will take a long time to get rid of, so I stopped at the point where I was determining if I absolutely needed certain registry values, like the InProcServer32 stuff.
Reply 15653 of 27644, by amontre
appiah4 wrote on 2020-05-21, 12:26:
amontre wrote on 2020-05-21, 11:57:
Today, I had my MiSTer with Minimig core installed on my candy arcade cabs (using a jamma adapter), I'm having a blast playing amiga games on the arcade.
Could you please give me a brief rundown on what makes a MiSTer different from a MiST?
It basically like steroid version of MiST, It has bigger FPGA and faster processor. In term of development of the cores, MiSTer are much more active almost weekly update of the cores.
NEC Pentium 133 | 96mb RAM | 40gb HDD | s3 Virge DX | Voodoo 2 | SB AWE64 Gold | Roland MT-32 & SC 55MkII
Reply 15654 of 27644, by pentiumspeed
Received 3.96mm pitch female connectors with pigtail of wires. Cut off the protruding bits and cut the latch off and I was able to plug these into power supply pins on the Compaq Deskpro 386/25e motherboard. Now searching to find ATX connectors and make adapter to power the motherboard.
Cheers,
Great Northern aka Canada.
Reply 15655 of 27644, by xjas
xcomcmdr wrote on 2020-06-01, 06:49:
How did you find D2X-XL to get going? I just set it up on my current rig for my source port archiving project and found it was an enormous finicky mess to even get running. ONCE everything was set up exactly how it's written in the manual, and you've worked out all the config stuff that has been changed but not documented, it runs "OK" but it's still littered with issues. Framerate varies from 400+ to sub-20FPS in the same room if you max out the settings (especially "smoke".)
I check it out every couple years or so - the author's put a bunch of really cool features and mods in that I would love to explore further - but I always have so many issues I go back to Rebirth ... or vanilla.
Reply 15657 of 27644, by Bruninho
I managed to customize a folder in XP to look like Windows 98 Web View Folders. However I can only apply it to one folder per time, not to all folders systemwide. I don't know yet how.
JOBS, Steve.
Reply 15658 of 27644, by mothergoose729
My son helped me install some PCI cards for my socket 478 windows 98 machine. He begged me to play some games on it, so we played unreal gold on a voodoo 3. He had a blast.
He really enjoyed the "jewel gun" aka the stinger.
Reply 15659 of 27644, by RetroLizard
mothergoose729 wrote on 2020-06-02, 02:46:
Did you play the game together on seperate computers? 😉
