Reply 1580 of 1953, by NeoG_
StriderTR wrote on 2025-08-31, 21:16:
I assume I know the answers, but, I just want to confirm.
In GUS mode, everything works great, except Fasttracker 2, but I assume that's a RAM limitation on larger modules. Smaller ones work. FT2 shows 1023K available. Is that using some of the 2MB storage since a Pico only has 264KB of SRAM?
The PicoGUS uses the external PSRAM chip to store GUS sample data yes. The last version of FT2 (2.09) has faulty GUS support, so make sure you are using 2.08 (or the new 2.10+ modern releases) and also yes modules larger than 1MB will not fit inside GUS memory. Impulse Tracker can auto downgrade 16-bit samples to 8-bit which can help some >1MB mods fit.
In Sound Blaster mode, can't get FT2 to work at all, not sure why, it just crashes when you play anything.
Not sure about this one, I can use FT2 in SB mode on firmware version 3.2.0 without crashes. Could potentially be irq/dma/address config issues.
DN3D needs 16-bit DMA and also wont work in this mode (no sound FX). Works great in GUS! Assume it's the lack of 16-bit DMA.
DN3D always asks for a 16-bit DMA but ignores it if you select 8-bit mixing, any 16-bit DMA value will work when 8-bit mixing is selected (I just set it as 5). Also set the card type to "Sound blaster 2.0", 8 voices, Mono, 22Khz.
Reply 1581 of 1953, by Isstanar
I'm having trouble with the PicoGUS 2.0 I just received and also having a Sound Blaster Live! in the same system.
My specs:
Asus MEB-VM
Sound Blaster Live! PCI
PicoGUS 2.0
ULTRASND set to 240,3,3,5,5
BLASTER set to 220,7,1
When I got the PicoGUS initially I just had the PicoGUS alone in the system alone and worked fine, but I needed sound in Windows 98 so I put in my SBLive card, installed the drivers, and found that the PicoGUS no longer worked correctly.
I tried DoomII and Duke3d. On both games the music worked fine, but was slow to initiate. The sound effects would not initialize for either game though. I tried switching the GUS port but when I do pgusinit /gusport 240 nothing would happen and I moved the jumper to DMA 3 which didn't help. So, is it not possible two have two cards with the PicoGUS or is some setting of mine wrong?
Edit: I ran in pure DOS mode and the soundfx initialized fine. Would be nice to have it work in Windows98 too, but I realize PicoGUS was designed for DOS.
Reply 1582 of 1953, by NeoG_
Isstanar wrote on 2025-09-06, 23:09:
Since you have a mixed non-PnP and PnP/PCI system, you should go into the bios and remove the PicoGUS's IRQ and DMA from the PnP assignment pool so windows doesn't try and assign any devices to the same values. Then check if the Live! drivers you installed have SB16 emulation enabled and de-conflict the IRQ/DMA if you want to keep it, or disable it entirely and just rely on the PicoGUS.
The PicoGUS does work in windows but you need to make sure the mode is set before windows loads and you try to install the drivers for that mode. I also wouldn't recommend trying to dynamically switch modes while in windows, just stick to one mode as DOS doesn't care if a hardware device is not responding unless you try to run a piece of software that needs it. Windows drivers may interact with the hardware device at any time and act unpredictably if the hardware device doesn't respond.
If you aren't installing any windows drivers and are just using DOS software that directly accesses the hardware it should be OK (but still need to make sure all IRQ and DMAs are clear). E.G. if you have your parallel port enabled it will use IRQ 7 which is the same as the PicoGUS.
Side note, the PicoGUS can only occupy one IRQ and DMA as set on the card jumpers. The ULTRASND and BLASTER variables need to reflect that. EG if your PicoGUS is on IRQ7 and DMA1 ULTRASND would be "240,1,1,7,7" and BLASTER would be "A220 I7 D1 T3" respectively.
Reply 1583 of 1953, by Isstanar
NeoG_ wrote on 2025-09-07, 00:42:
Since you have a mixed non-PnP and PnP/PCI system, you should go into the bios and remove the PicoGUS's IRQ and DMA from the PnP […]
Thank you! That's what I needed to know and I got it working now. I reserved DMA 3 in the bios, corrected the blaster settings, and now I got things working. I didn't install the dos drivers yet for the Live! but that's the next step so I can leave the picoGUS on GUS mode. I actually knew to disable all the extra serial and parallel ports at least, but I'm starting to remember all these little details now from the past.
Are there windows drivers for PicoGUS? Because I couldn't find anything beyond that it was DOS only.
Reply 1584 of 1953, by NeoG_
Isstanar wrote on 2025-09-07, 15:44:
There aren't any windows drivers specific to the PicoGUS - What does work (MPU, Adlib, SB, CDROM.. not sure about GUS) uses the built in windows drivers. But since it's a non PnP card it has to be manually added with add new hardware and the resources manually assigned same as you would with the real hardware. Using the windows MPU driver, it will insist on taking IRQ9 as well but auto assignment should de-conflict that on the next boot and it works as a simple MIDI port on 330 without the card also having IRQ9.
Reply 1585 of 1953, by DustyShinigami
When I come to order one from Serdashop, should I add any additional GM/GS or LAPC bundles?
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 1586 of 1953, by badmojo
DustyShinigami wrote on 2025-09-10, 09:27:
Yes.
Reply 1587 of 1953, by MadMac_5
badmojo wrote on 2025-09-10, 11:35:
Yes.
I know that my PicoGUS pairs very nicely with the X2GS that I'd purchased a couple of years before. Right now the PicoGUS is set up purely as a MPU-401 device alongside my Vortex 2 sound card for Sound Blaster compatibility; I've also run it alongside an AWE 64 to get a bug-free MPU-401 that works well with TIE Fighter.
Reply 1588 of 1953, by NeoG_
I ordered mine with the 3.5" front display and a WP32 McCake. I have been very happy with the WP32 hanging off the wavetable header, especially for MT32 games. Now with GeneralUser GS 2.0+ the GM side is also much more SC-55 like and works well with games. The front display seemed cool at first and was useful for troubleshooting but now it's been on there for a bit I don't think it suits the aesthetic of most systems it would go in to.
Reply 1589 of 1953, by justin1985
I've started messing around with PC/104 boards (have 2 based on Geode GX1/ Cyrix Media GX) and would love to use a PicoGUS with them! I found some listings for people selling one-off productions, which all seem to be sold out now.
This project on GitHub seems promising ( https://github.com/UzixLS/picogus104 ), and uploads smoothly to PCBWay (awaiting audit). Has anyone tried using this project this way?
Reply 1590 of 1953, by Flywheel
Has anyone tried or have had success simultaneously using a USB mouse and CD-ROM emulation through a powered USB hub? I have tried with a couple of modern USB hubs but do not currently have a 1.1 hub to test with. I have been able to use the mouse functionality through one of my two modern hubs but neither would detect the USB sticks as a CD-ROM. Both work just fine when plugged in directly to the Picogus.
Reply 1591 of 1953, by Treah
Has anyone ever had issues with the USB mouse support on this device? I cant get it to work at all... It will detect that a mouse is there via ctmouse but when I move the mouse I get nothing on the mousetst command. It also wont work in windows 3.11. Dunno if this is just my system or something else is going on.
Also when I do have the picogus where it can emulate a USB device as serial my onboard serial ports behave the same way even with an old MS Home mouse.. They get detected but no data is actually sent from the mouse.
Reply 1592 of 1953, by douglar
Flywheel wrote on 2025-09-12, 15:56:
I think the experience with usb 1.1 hubs is often poor. They introduce too much latency. Try the other direction. Look for a faster, powered hub that has lower latency and look for faster usb storage.
Reply 1593 of 1953, by sampson
First of all, PicoGUS is amazing! Ian, if you see this, thank you for your contributions to the community. I can build my childhood dream computers now 😀
I'm having a minor issue and wondering if anyone else is observing the same thing.
I'm on the PicoGUS 2.0 and updated to the 3.2.0 FW with the matching pgusinit.exe 3.7.0. The CD emulation, and everything else I've tried, is working perfectly over the last few weeks. However, I am observing a hang (apparent soft-lock) in pgusinit.exe when attempting to change the sound card mode, if I have a McFly wavetable board installed.
After "pgusinit /mode XYZ" it successfully detects the PicoGus and the FW/HW versions. It shows "Mode change requested." followed by "Rebooting to fw: XYZ...". It hangs here indefinitely with a blinking cursor, but Caps Lock does not toggle the LED indicator on the keyboard. Power cycle needed to recover; CTRL-ALT-DEL does not work.
It doesn't matter which sound card mode you start with, nor the target mode. After removing the wavetable board, there is no issue changing modes. After changing modes, it is possible to reinstall the wavetable card and it will function as normal. I have a McCake, but haven't had a chance to try it yet. I can do this if it's helpful.
I'm using a Pocket 386 with Windows95 aka DOS 7.10. I've tried real-mode and protected-mode, with and without various UMB/EMS/XMS settings. I tried with and without a CD image loaded with USB flash drive present and not present. Simply removing the wavetable card sorts it out. Take care!
Reply 1594 of 1953, by NeoG_
sampson wrote on 2025-09-14, 05:24:
It would be useful to see if it's any wavetable card that causes it, or specifically the McFly
Reply 1595 of 1953, by Niemi_81
Hello guys! I was super excited to get my Picogus 2.0. Plan was to use SB mode for some CD gaming and GUS mode for demos.
After getting everything set in autoexec.bat & config.sys i am having trouble accessing emulated CD drive.
Sometimes it shows image file loaded, sometimes not. PGUSINIT / CDLIST never works. Same thing in USB mode. Any tips for me or could my Picogus be faulty. Thanks!
Reply 1596 of 1953, by Yoghoo
Niemi_81 wrote on 2025-09-14, 17:50:
Make sure the USB stick is formatted with FAT32. Also make sure you don't have too many images on your USB stick. If that's the case already try some other USB sticks. My experience is that not all USB sticks work as expected.
Reply 1597 of 1953, by sampson
NeoG_ wrote on 2025-09-14, 09:30:
Fair enough 😀 I just tried it with the McCake and observe the exact same behavior. I don't have any other wavetable cards to try.
Reply 1598 of 1953, by sampson
Which flash drive brand/model, capacity, and partition configuration?
I have a bunch of different brand-name USB flash drives, ranging in age from 6-12m old, to 8-10yr old, and in various capacities. Some flash drives work flawlessly, and some not-so-much. I see the same thing with the CH375 interface as well. For my PicoGUS I am using a Sandisk Extreme Pro 256G at the moment. It is configured with an 8GB FAT32 partition, with the rest of the capacity unallocated. I have several Team Group flash drives in 32GB and 128GB capacities and they also work well with both solutions (again, using 4-16GB partitions). I've got a couple flash drives that just act flaky and unreliable. Good luck!
Reply 1599 of 1953, by Poot36
@polpo Sorry if this has been asked before but is it possible to have a PCB that is 102mm wide to get the cheaper PCB option from JLC PCB? I do realize that it would not reach the back of the computer case but I am ok with that. I would try changing it myself but have no clue how to use the PCB software that it was designed in. The PCB is the V1.2 version.
