Reply 16 of 57, by aqrit
the "Microsoft\DirectDraw\MostRecentApplication" registry key is not updated consistently... this causes a silent fail?
keep trying until the Name under the MostRecentApplication key matches the name of your target application (see the manual instructions in the link I've previously provided)
Reply 17 of 57, by SKARDAVNELNATE
Miki Maus wrote:
Try using D3DWindower.
Using one last XP system that still has the display problem I had to copy D3dHook.dll the Torment folder. Then I tried different options and found that DDraw Emulate corrected it.
Since it's now displayed in a window, using the mouse to scroll off the edges doesn't work. If it could be set to go full screen it would be a much better solution.
I think the height and width labels are reversed in the one I downloaded since a window 950 high by 1250 wide turned out to be really tall and narrow.
Reply 19 of 57, by Jorpho
Can I ask how you made that, exactly? Did you use a debugger?
Reply 20 of 57, by aqrit
Used a debugger
Here is exactly how I made it
Problem Description:
Cursor artifacts occur when using fully emulated directdraw and running fullscreen
they don't occur when using fully emulated directdraw and running windowed
so to find a cure:
Make sure DirectDrawCreate is passed the DDCREATE_EMULATIONONLY flag
(so we have mouse trails)
Find what accesses the string "Full Screen"
Find the address where the obligatory 'IsFullScreen' value is stored
Log each instance where the IsFullScreen value is accessed.
For each instance patch the code so false is used instead of true.
launch the game and see if the problem is fixed
repeat until it is. 😁
Reply 22 of 57, by aqrit
trying to use D3dWindower to run fake full screen is a pain (and not perfect)
I haven't reversed far enough to know what the ultimate problem is.
What side effect of D3DWindower is fixing this?
(using GDI for rendering? not creating surfaces in video memory?)
my solution could be dropped into one of the tweak packs and people wouldn't ever have to deal with this issue.
(or D3DWindower, or Shiftwindow, or NvidiaFix, or MS ACT, or update their video drivers, or the HW acceleration slider, or fake desktop resolutions)
In fact, that entire thread could be deleted.
Reply 23 of 57, by Jorpho
aqrit wrote:
Used a debugger
Which one? IDAFree?
Reply 24 of 57, by aqrit
I used:
IDAFree as a disassembler
OllyDbg (v1.10 and v2.0) as a debugger
Cheat Engine to log what accessed the IsFullScreen value
CFF Explorer for examining/altering the PE header
Dependency Walker for viewing imports
MSVC Express 2008 for compiling my api hooks/code injection test stuff
dx7sdk for directdraw documentation
Hxd as a hex-editor
Reply 25 of 57, by aqrit
back on topic...
The DirectDraw\\MostRecentApplication value almost never updates (for me)
but a quick google shows that the "ID" value is just the TimeDateStamp in the PE header of the target executable
So this program could be greatly simplified/improved...
Reply 26 of 57, by mudlord
Okay,
I stopped making this ever since Sol_HSA made the proper ddhack emulator/hack, but what exactly do you want done.
I might get off my ass to fix, or update this. If I am motivated enough. 😦
Reply 28 of 57, by Good Ol' TarviS
aqrit wrote:
something like this?
http://users.cjb.net/aqrit/ddraw_color_fixer.zip (includes source)
*** not tested on x64 ***
As far as I know, this does the exact same thing as the program in the OP.
Reply 29 of 57, by aqrit
It gets the 'ID' value in a way less prone to failure.
Though the program itself is probably less reliable. (because it was written in a hurry)
Did you read the posts in your own thread?
specifically these three:
mudlord's Windows 7 DDraw Compatability Fix (Fixes Garbled Colors)
Reply 31 of 57, by achillies000
1) App gets HWND/process IDs of application being run.
2) App runs the application.
3) It kills its threads as soon as a HWND and thread ID is gathered.
4) From there, the most recent DirectDraw application ID is gathered. Since it was the app to be patched, it copies it to a variable.
5) This variable, along with the needed flags makes a compatibility profile in the Registry for Windows Vista/7 to use with that application, only. It won't affect other parts of your registry. The key name used comes from the application's window class name/IDs.
Reply 32 of 57, by aqrit
Read my comments in this thread... seriously
the first 4 steps are not optimal ->
and almost never work for me (and others)
a better method:
1) Get TimeDateStamp from target executable
2) Add key to registry (the key name can be anything)
Reply 33 of 57, by feda
Both ddraw color fixes given in this thread work only partially with UFO Defense collector's edition. The colors are correct for everything except the intro movie which still looks like a tie-dye.
They both work well with TFTD, though (except the initial language selection screen, but that's not a problem).
Thank you to both fixers.
Reply 34 of 57, by dosmax
For some (many?) games that have color palette problems there is a very simple fix that doesn't require any extra files, manual editing of the registry or tinkering with the Application Compatibility Toolkit:
Disabling Desktop Composition (Aero) in a programs Compatibility Settings might very well be enough. At least on my Win7/32.
So if you use a 32bit Windows, before trying anything else, try this. Works quite often. In general for everything that works with the infamous "open the Screen Resolution window" workaround.
Reply 35 of 57, by Good Ol' TarviS
This does work sometimes, but it's less convenient and does not work for many games.
