Reply 160 of 311, by nd22
- l33t
Memory timings are 3-3-3-8 CR1T and the latest BIOS version is used on both boards; all Newcastle come with the CG stepping:
To summarize the hardware and software used:
System 1 - socket 754:
CPU: Athlon 64 3400 Newcastle
Cooler: Arctic freezer 64 pro
Motherboard: Abit NV8 with nforce4 chipset
RAM: corsair 2*1gb at 3-3-3-8 CR 1T timings
GPU: radeon x19590 pro
SSD: Kingston 960gb SATA3 that works perfectly on all nforce4 boards!
HDD: WD 74gb raptor for storage tests
ODD: some SATA DVD-RW that I got from storage
PSU: Antec true power trio 650w - I bought it back in 2008; inspected before testing, still works just fine
System 2 - socket 939:
CPU: Athlon 64 3800 Newcastle
Motherboard: Abit KN8 with nforce4 chipset
Drivers:
- nvidia chipset driver 15.23 - latest for nforce4
- radeon driver 10.2 - latest and greatest for radeon!
- realtek AC97 driver version 4.06
Software:
- Windows XP SP3 with net framework 2.0 installed
- msi afterburner 4.30
- fraps 3.4.7
- irfanview for all screenshots
- everest 5.50
For easier viewing I selected the default Luna theme with the green variation for the Socket 939 with Newcastle 3800 and Royale theme for the Socket 754 with Newcastle 3400. Athlon 64 3800 will always be first, Athlon 64 3400 second.
1. First test is Code creatures pro at default settings - that means no AA, no sound:
A. Athlon 64 3800 - socket 939
B. Athlon 64 3400 - socket 754
Socket 939 got a 6% lead thanks to dual channel, still quite far from the 11.76% PR difference!
2. Same as above only with sound this time:
Only 3% separates now the 2 Newcastle - the difference in the ratings just doesn't add up!
3. Same resolution but with AA this time as it is the only quality setting - besides the resolution and sound - that can be modified in Code creatures pro:
4. The difference shrinks ever more! Time to test with sound:
Please note the very low impact of sound over the results despite the fact that nforce4 uses the same old AC97 codec!
5. We increase the resolution to 1280*1024 - standard for 17 and 19 inches monitors that can be had for practically nothing today!
6. We stay at the same 1280*1024 resolution and test with sound and got the following:
Just under 2% is the advantage the dual channel socket 939 has over the single channel socket 754!
7. And now the last resolution: 1600*1200
8. Final and most demanding settings: 1600*1200, AA 4x with sound:
Despite using an overpowered radeon x1950 pro in this DirectX8 benchmark the difference between socket 939 and socket 754 is far below the performance rating difference of these 2 processors!
Maybe we can get better scaling in the next benchmark which is Aquamark3!
9. Aquamark3 is the first DirectX9 benchmark ever released! Very tough on the first generation of DirectX9 video cards, with a radeon x1950 pro surely there is no GPU bottleneck.
Default settings first; the parameter we are interested in is the average FPS not the score!
Barely 4.1% separates the 2 Athlon’s!! Until now all tests reveal that the performance difference is around 4-5%!
10. We stay at 1024*768 but select maximum details and sound:
11. Next is the 1280*1024 resolution at maximum details; without sound first:
12. .. and with sound:
It seems that the socket 939 platform perform better in all tests with sound as the delta between it and its older brother - socket 754 - increases in all tests that include audio!
13. One more time we increase the resolution to 1600*1200:
And the difference is less than 1%! Surely this is not what AMD was thinking when it decided to release socket 939!
14. Final and most demanding settings: 1600*1200 max details+ sound:
Aquamark3 puts the difference between the 2 identically clocked CPU's at no more the 4.75% even when using the lowest settings. Until now dual channel did not bring the breakthrough the Athlon 64 3800 badly needs.
15. We go back in time to the only DirectX7 benchmark in the entire suite: 3dmark 2000. Purely a CPU test with the x1950 pro it is not a challenge for any of the 2 systems. Default settings first:
