Release Announcements Consolidation
Reply 162 of 247, by Stiletto
ANGLE - Chrome component
Translates WebGL (subset of Khronos OpenGL ES 2.0) to Direct3D 9.
http://code.google.com/p/angleproject/
http://code.google.com/p/angleproject/w/list
http://blog.chromium.org/2010/03/introducing- … le-project.html
http://blog.chromium.org/2011/11/opengl-es-20 … -for-angle.html
https://groups.google.com/forum/?fromgroups#! … um/angleproject
do the Fandango!" - Queen
Stiletto
Reply 168 of 247, by Stiletto
DosFreak wrote:
TOPBENCH – A tool for PC retrogaming and retrocomputing enthusiasts
http://dosbenchmark.wordpress.com/
http://www.vintage-computer.com/vcforum/showt … a-new-benchmark
woohoo, congrats to MobyGamer (here on VOGONS)
I expect it will have its own thread in Marvin shortly 😁
Stiletto
Reply 172 of 247, by VileR
the Fake86 PC emulator has had some pretty extensive updates;
http://sourceforge.net/projects/fake86/
Features […]
Features
Full support for the 16-bit 80186 instruction set. (80386 CPU emulation coming soon)
Emulation of the major support chips found in 1980's era PCs.
Audio support includes emulation of the Sound Blaster Pro, Adlib FM music card, Disney Sound Source, and standard PC speaker.
Standard Microsoft-compatible serial mouse emulated on COM1.
Hard/floppy disk emulation on interrupt 13h using disk image files.
Capable of running any 16-bit flavor of DOS. (MS-DOS, DR-DOS, PC-DOS, FreeDOS, etc.)
Hercules, CGA, MCGA, and VGA (except 640x480 16-color) video emulation. (EGA and full VGA support coming soon)
Ethernet emulation with libpcap and WinPcap.
Reply 173 of 247, by eL_PuSHeR
Interesting.
Reply 174 of 247, by Stiletto
DosFreak wrote:
Website with links to Vmware Player\Workstation downloads
http://notepad.bttr-software.de/blog/rr/2012/ … mware_player_50
Nice, many months ago this was a pain in the butt to find older versions. 😀
Stiletto
Reply 176 of 247, by WolverineDK
DosFreak: I hope it is okay. That I am sharing the links else where, or at least some of them. And also I do give credit, when I am "stealing" your links at the other place. So I am not a thief , per se. But on the contrary I am sharing the caring of it.
Reply 177 of 247, by DosFreak
http://code.google.com/p/lavfilters/
Open-Source DirectShow Media Splitter and Decoders
LAV Filters are a set of open-source DirectShow filters, aimed to eventually replace the better part of the playback chain required to play all and any modern media.
LAV Splitter is a Souce Filter/Splitter required to demux the files into their separate elementary streams.
LAV Audio and Video Decoder are powerful decoders with a focus on quality and performance, without any compromises.
All LAV Filters are based on the FFmpeg multimedia libraries (licensed under GPLv2)
Make your games work offline
Reply 178 of 247, by DosFreak
OpenAL Soft
http://kcat.strangesoft.net/openal.html
Overview […]
Overview
OpenAL Soft is an LGPL-licensed, cross-platform, software implementation of the OpenAL 3D audio API. It's forked from the open-sourced Windows version available originally from the SVN repository at openal.org.
OpenAL provides capabilities for playing audio in a virtual 3D environment. Distance attenuation, doppler shift, and directional sound emitters are among the features handled by the API. More advanced effects, including air absorption, occlusion, and environmental reverb, are available through the EFX extension. It also facilitates streaming audio, multi-channel buffers, and audio capture.
About This Project
This library is a compatible update/replacement to the deprecated OpenAL Sample Implementation (the SI). The original idea was to fork the old Windows version to attempt an accelerated ALSA version. The accelerated ALSA idea quickly fell through, but the software mixing code ended up being modified to be cross-platform, with multiple output backends: ALSA, OSS, DirectSound, PulseAudio, MMDevAPI, CoreAudio, Solaris, SoundIO, WinMM, PortAudio, "Null" Output, and a .wav writer are currently implemented.
OpenAL Soft's code has been improved to support mono, stereo, 4-channel, 5.1, 6.1, and 7.1 output. OpenAL Soft does not support the Vorbis and MP3 extensions, however these are considered deprecated. It does, though, support some of the newer extensions like AL_EXT_FLOAT32 and AL_EXT_MCFORMATS for multi-channel and floating-point formats, as well as ALC_EXT_EFX for environmental audio effects, and others.
Reply 179 of 247, by DosFreak
Posted by aqrit in another post:
Microsoft Attack Surface Analyzer
http://www.microsoft.com/en-us/download/detai … s.aspx?id=24487
Attack Surface Analyzer is developed by the Trustworthy Computing Security group. It is the same tool used by Microsoft's internal product groups to catalogue changes made to operating system attack surface by the installation of new software.
Attack Surface Analyzer takes a snapshot of your system state before and after the installation of product(s) and displays the changes to a number of key elements of the Windows attack surface.
