Reply 160 of 180, by dr.zeissler
Hi cloudschatze, I'll try to use a LPT-Zipdrive and there are some LTP-CDROM-Drives too. Don't know if these will work. Currently I am checking the XTA2SD.
It works but I don't have benchmarks jet. Copying from floppy seems to be not so fast, but I have to make some benches. I am using Dos from ROM and then
use config.sys and autoexec.bat from the harddrive. I'll upgrade from actual 1x 20MB to 2x32MB. I also checked *.fli's but they seem to be too slow on that tandy.
- Beside that I would like to know what games/demos work with OPL2/3LPT ? can the OPL be routed to 388h on the tandy?
- What image-viewer are you using on the tandy?
My scene-archive has currently no OPL supported or tandy-sound supported productions, only no-sound or PC-speaker. If you have other stuff, then please share.
Best regards
Doc
