S3 AGP Cards (and possibly others) Too Bright
Reply 160 of 165, by analog_programmer
Jepael wrote on 2016-06-02, 18:58:
Here are two simple DOS .com programs to either turn the bit on or off, but I haven't tested these. I used NASM to compile these so I haven't tested them on S3 card. These are so simple you could just do these in debug and save them.
S3BLACK.COM does not work with my PCI S3 ViRGE/GX (as well as S3BRIGHT.COM). So I decided to make new DOS executable for fixing the "too bright" BIOS bug of ViRGE/GX with LCD displays. Probably it will work on ViRGE/DX - test it.
P.S. I'm sorry for "digging up the dead guy". I decided to share my version of ViRGE/GX bright bug fix tool.
Updated attachment: COM executable replaced with EXE.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 161 of 165, by Gmlb256
analog_programmer wrote on 2023-06-30, 21:57:
S3BLACK.COM does not work with my ISA S3 ViRGE/GX (as well as S3BRIGHT.COM). So I decided to make new DOS .com executable for fixing the "too bright" BIOS bug of ViRGE/GX with LCD display. Probably it will work on ViRGE/DX - test it.
P.S. I'm sorry for "digging up the dead guy". I decided to share my version of the little ViRGE/GX tool.
Glad that you shared the utility, which is convenient. It will work 100% with ViRGE/DX since it is very similar to the ViRGE/GX sans support for SGRAM.
The one written by Jepael were intended for late S3 video cards starting from the ViRGE/GX2.
Reply 162 of 165, by marxveix
S3BLACK.COM does not work with my PCI S3 ViRGE/GX (as well as S3BRIGHT.COM). So I decided to make new DOS executable for fixing […]
Does this work with GX2 AGP? I have this problem with my GX2 and S3BRIGHT did not work as i remember.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 163 of 165, by analog_programmer
marxveix wrote on 2024-03-27, 11:49:
I can confirm that it works with ViRGE/DX and GX PCI versions. I don't have any S3 ViRGE/GX2 AGP card, so I can't confirm/deny if it works with these videocards. You can try the tool with your GX2 AGP card, it's harmless as it is not permanent solution for the bright bug. If there's some issue, just restart the machine.
Reply 164 of 165, by Hugonl40
I have a STB S3 P86C801 that has this issue, would any of these .exe/.com solutions work for this card?
Reply 165 of 165, by wedge
Hello,
Using previous post (Re: S3 AGP Cards (and possibly others) Too Bright) I created a simple batch file ""S3 ViRGE/DX Black level Patch 1.0" to load just the necessary instructions in DEBUG autonomously for the S3 ViRGE/DX (2MB PCI)
You can edit easily if it doesn't work on specific a S3 ViRGE.
The attachment S3VDXBLK.zip is no longer available
Cheers
