List of rarest PC soundcards
Reply 160 of 247, by elianda
Isn't CN4 just connected to the audio jacks?
Youtube Channel
Reply 161 of 247, by keropi
this is just a vga, the sound jacks only get activated if you install the mpeg decoder addon so you can mix your main soundcard output with the addon.
Re: What MPEG daughterboards attach to S3 cards?
Reply 162 of 247, by retardware
Looks like @keropi is right.
Took the card out of the storage and looked clearly at it.
The "Philips sound chips" are HEF4051, 🤣.
The upper jack is "Line in", the lower one "Line out".
Thanks for solving that miracle... always wondered what this strange card is...
Reply 163 of 247, by easy_john
I believe this board don't have soundcard parts and this audio jacks is only for mpeg accelerator module that can be added to feature connector.
Oops. Already answerd. Need refresh browser pages often :)
Pentium2 450/256mb/4gb/ati rage 128+voodoo2/SB awe32 8mb+db50xg/GUS PnP 8mb/TB Tropez 2mb
486 DX2-66/32mb/8gb/tseng4000 2mb/SB 16+WB/GUS 1mb/LAPC-I
286 12mhz/4mb/512mb/Vga 1mb/SB 2.0+Covox
PegasosII G4 / Amiga 4000 / Amiga1200 / Amiga 600
Reply 164 of 247, by peklop
Hi,
still searching for photo of the JDF-SOUNDMEDIA001. Card with Yamaha YMZ263B chipset like Adlib Gold.
A found only old discussion from 1997 or 1998 and dead link to ebay.
Have someone real card or saved photos of the card?
Reply 165 of 247, by bristlehog
peklop wrote on 2020-01-12, 17:05:
Hi, still searching for photo of the JDF-SOUNDMEDIA001. Card with Yamaha YMZ263B chipset like Adlib Gold. A found only old discu […]
Hi,
No, but I narrowed it down to some Western Digital Paradise sound card and put into the list.
Also, I added lots of obscure sound cards, FCC IDs, pictures and other stuff. The list now contains almost 150 sound cards. Guys, see if you own something and modify owners columns accordingly.
Hardware comparisons and game system requirements: https://technical.city
Reply 166 of 247, by bristlehog
I have compiled a large list of sound cards from Microsoft's knowledge base archive. Might be of use, has some technical info.
SUMMARY
The following is a list of some of the major sound card manufacturers. Phone
numbers and specifications are included.
Acer America
Model: Acer PAC Magic
Phone: (408) 432-6200
Warranty: 1 Yr.
Computer Interface: 16-bit ISA (AT) only
IRQ's Above 7 Supported: Yes
DMA Channels Above 3 Supported: No
Max Sample Rate-Recording in kHz: 48
Max Sample Rate-Mono Playback in kHz:48
Max Sample Rate-Stereo Playback in kHz: 48
DSP Included: No
ADPCM Data Compression Supported: Yes
Synthesizer Type: FM4, Optional Wavetable
Synthesizer Chipset: OPL3
MIDI Interface Included: Yes
Adlib Compatible: Yes
Sound Blaster Compatible Via: FM Chip
Via MPU-401 Emulation: No
Onboard Mixer: Yes
CD-ROM Interface: Proprietary
ACS Computer
Model: Futura 16
Phone: (415) 875-6633
Warranty: 1 Yr.
DSP Included: No
Via MPU-401 Emulation: UART
Onboard Mixer: Yes
CD-ROM Interface: Proprietary or optional SCSI
Actix Systems
Model: Lark
Phone: (408) 986-1625
Warranty: 1 Yr.
Computer Interface: Any ISA
Show last 1441 lines
Max Sample Rate-Recording in kHz: 44
Max Sample Rate-Mono Playback in kHz:44
Max Sample Rate-Stereo Playback in kHz: 44
DSP Included: No
Onboard Mixer: Yes
CD-ROM Interface: SCSI w/ ASPI
Actix Systems
Model: Lark
Warranty: 1 Yr.
Computer Interface: VESA Local Bus
DSP Included: No
Onboard Mixer: Yes
Ad Lib Multimedia Inc.
Model: Ad Lib Gold 1000
Phone: (418) 656-8742
Warranty: 1 Yr.
DSP Included: No
Synthesizer Chipset: OPL3 YMF262
Onboard Mixer:
CD-ROM Interface: SCSI Optional
Addtech Research
Model: Sound Pro II
Phone: (510) 623-7583
Warranty: 1 Yr.
DMA Channels Above 3 Supported: Yes
DSP Included: Yes
Synthesizer Type: Wavetable
Synthesizer Chipset: Aria, TMS320 DSP
Sound Blaster Compatible Via: SW emul
Onboard Mixer: Yes
CD-ROM Interface: None
Advanced Gravis
Model: Ultrasound
Phone: (604) 431-5020
Warranty: 3 Yr.
DSP Included: No
ADPCM Data Compression Supported: No
Synthesizer Chipset: GFI
Onboard Mixer: Yes
Advanced Gravis
Model: Ultrasound Max
Warranty: 3 Yr.
DSP Included: No
Onboard Mixer: Yes
CD-ROM Interface: Proprietary and SCSI
AITech International
Model: Audio Show
Phone: (510) 226-8960
Warranty: 1 Yr.
DSP Included: No
Onboard Mixer: Yes
CD-ROM Interface: SCSI w/ASPI
Model: Audio/Video Blender
Warranty: 1 Yr.
DSP Included: No
MIDI Interface Included: No
Onboard Mixer: Yes
CD-ROM Interface:
Alpha Systems Lab
Model: Cyber Audio Pro
Phone: (714) 252-0117
Warranty: 2 Yr.
DSP Included: Yes
Sound Blaster Compatible Via: HW Emul
Onboard Mixer: Yes
Antex Electronics
Model: Z1
Phone: (310) 532-3092
Warranty: 1 Yr.
Max Sample Rate-Recording in kHz: 50
Max Sample Rate-Mono Playback in kHz:50
Max Sample Rate-Stereo Playback in kHz: 50
DSP Included: Yes
Onboard Mixer: Yes
Antex Electronics
Model: Z1e
Warranty: 1 Yr.
DSP Included: Yes
Onboard Mixer: Yes
Aztech Labs
Model: Sound Galaxy Basic 16
Phone: (510) 623-8988
Warranty: 1 Yr.
DSP Included: Yes
Onboard Mixer: Yes
Best Data Products
Model: ACE 5000
Phone: (818) 773-9600
Warranty: 2 Yr.
DSP Included: Yes
Synthesizer Chipset: Mwave DSP Crystal Codec
Sound Blaster Compatible Via: SW Emul
Onboard Mixer: No
CD-ROM Interface:
Best Data Products
Model: ACE 5000
Warranty: 2 Yr.
IRQ's Above 7 Supported: No
DSP Included: Yes
Synthesizer Type: Optional Wavetable
Synthesizer Chipset: Ensoniq
Onboard Mixer: Yes
Boca Research Inc.
Model: Sound Expression 14.4VSp
Phone: (407) 241-8088
Warranty: 5 years
Max Sample Rate-Recording in kHz: 44.1
Max Sample Rate-Mono Playback in kHz:44.1
Max Sample Rate-Stereo Playback in kHz: 44.1
DSP Included: No
Adlib Compatible: No
Onboard Mixer: No
CD-ROM Interface: Sony, Panasonic, Mitsumi, Enhanced IDE
Calypso Micro Products
Model: Audio Magician
Warranty: 1 Yr.
Max Sample Rate-Recording in kHz: 22
Max Sample Rate-Mono Playback in kHz:22
Max Sample Rate-Stereo Playback in kHz: 22
DSP Included: No
Synthesizer Type: FM2
Synthesizer Chipset: OPL2
Onboard Mixer: Yes
Model: Audio Magician 3D
Phone: (408) 379-9494
Warranty: 1 Yr.
DSP Included: No
Onboard Mixer: No
CD-ROM Interface:
Cardinal Technologies
Model: Digital Sound Pro 16
Phone: (717) 293-3000
Warranty: 3 Yr.
DSP Included: Yes
Synthesizer Chipset: Echo ESC624,Analog Dev. DSP
Via MPU-401 Emulation: UART and Smart
Onboard Mixer: Yes
Model: Digital Sound Pro 16 Plus
Warranty: 3 Yr.
DSP Included: Yes
Onboard Mixer: Yes
Creative Labs
Model: Sound Blaster 16 Basic Edition
Phone: (405) 742-6622
Warranty: 1 Yr.
DSP Included: No
Synthesizer Type: FM4, Optional Wave Blaster
Onboard Mixer: Yes
Creative Labs
Model: Sound Blaster 16 MultiCD
Warranty: 1 Yr.
DSP Included: Opt
Onboard Mixer: Yes
CD-ROM Interface: 3 Proprietary
Creative Labs
Model: Sound Blaster 16 SCSI-2
Warranty: 1 Yr.
DSP Included: Opt
Onboard Mixer: Yes
Criterion Computer
Model: Sound Genie
Phone: (510) 657-3898
Warranty: Life
DSP Included: Yes
Onboard Mixer: Yes
Criterion Computer
Model: Sound Genie Pro
Warranty: Life
DSP Included: No
Onboard Mixer: Yes
Diamond Computer Systems
Model: SonicSound
Phone: (408) 325-7100
Warranty: 2 Yr.
DSP Included: No
Onboard Mixer: Yes
Model: SonicSound
Warranty: 2 Yr.
DSP Included: Yes
Onboard Mixer: Yes
DSP Solutions
Model: Port-Able Sound Plus
Phone: (415) 494-8086
Warranty: 90 day
Computer Interface: Parallel Port
IRQ's Above 7 Supported: n/a
DMA Channels Above 3 Supported: n/a
DSP Included: Yes
Synthesizer Type: FM (in software)
Synthesizer Chipset: TI TMS320
Onboard Mixer: Yes
CD-ROM Interface:
Echo Speech
Model: Echo DSP
Phone: (805) 684-4593
Warranty: 5 Yr.
DSP Included: Yes
Synthesizer Chipset: Echo ESC624, Analog Dev. DSP
Onboard Mixer: Yes
Focus Information Systems
Model: 2-the-Max Music Maker
Phone: (510) 657-2845
Warranty: 2 Yr.
DSP Included: No
Onboard Mixer: Yes
Model: 2-the-Max Music Maker Pro
Warranty: 2 Yr.
DSP Included: Yes
Synthesizer Chipset: Euphonics
MIDI Interface Included: Opt
Onboard Mixer: Yes
Genoa Systems
Model: Audioblitz Stereo 16+ Mo. A3300
Phone: (408) 432-9090
Warranty: 2 Yr.
DSP Included: No
Onboard Mixer: Yes
Genoa Systems
Model: Audioblitz Stereo 16+ Mo. A3400
Warranty: 2 Yr.
DSP Included: Yes
Synthesizer Chipset: OPL4
Onboard Mixer: Yes
IBM
Model: M-Audio
Phone: (800) 887-7771
Warranty: N/A
Max Sample Rate-Recording in kHz: 88
Max Sample Rate-Mono Playback in kHz:88
DSP Included: Yes
Onboard Mixer:
CD-ROM Interface:
ImagiMedia
Model: Audio Image 16
Phone: (408) 453-9911
Warranty: 1 Yr.
DSP Included: No
Synthesizer Type: FM2, Wavetable
Synthesizer Chipset: BREVE
Onboard Mixer: Yes
Jovian Logic
Model: Sonia
Phone: (510) 651-4823
Warranty: 1 Yr.
DSP Included: Yes
Onboard Mixer: Yes
CD-ROM Interface:
KYE International
Model: SoundMaker 16
Phone: (909) 923-3510
Warranty: N/A
DSP Included: No
Onboard Mixer: Yes
Logitech
Model: SoundMan 16
Phone: (510)-795-8500
Warranty: 3 Yr.
DSP Included: No
Onboard Mixer: Yes
CD-ROM Interface:
Logitech
Model: SoundMan Wave
Warranty: 3 Yr.
DSP Included: Opt
Onboard Mixer: Yes
Media Innovations
Model: Powermedia
Phone: (408) 954-0611
Warranty: 1 Yr.
DSP Included: Yes
Onboard Mixer: Yes
CD-ROM Interface:
Media Magic
Model: DSP 16
Phone: (512) 339-3500
Warranty: 1 Yr.
DSP Included: Yes
Onboard Mixer: Yes
Media Magic
Model: DSP 16 Plus
Warranty: 1 Yr.
DSP Included: Yes
Synthesizer Chipset: Pro Sound
Onboard Mixer: Yes
CD-ROM Interface: Proprietary w/ASPI
Media Magic
Model: ISP 16
Warranty: 1 Yr.
DSP Included: Yes
Onboard Mixer: Yes
Media Vision
Model: Pro Audio 16 Basic
Phone: (510) 770-8600
Warranty: 3 Yr.
DSP Included: No
Onboard Mixer: Yes
CD-ROM Interface:
Media Vision
Model: Pro Audio Spectrum 16
Warranty: 3 Yr.
DSP Included: No
Onboard Mixer: Yes
Media Vision
Model: Pro Audio Studio 16
Warranty: 3 Yr.
DSP Included: No
Onboard Mixer: Yes
Mediatrix Peripherals
Model: Audiotrix Pro
Phone: (819) 563-6722
Warranty: 1 Yr.
DSP Included: No
Synthesizer Type: FM4, Wavetable
Onboard Mixer: Yes
CD-ROM Interface: Optional w/ASPI
Microsoft
Model: Windows Sound System
Phone: (206) 882-8086
Warranty: Life
DSP Included: No
Onboard Mixer: Yes
CD-ROM Interface:
Midi Land
Model: Concurrent Sound Card
Phone: (909) 595-0708
Warranty: 1 Yr.
DSP Included: Yes
Synthesizer Chipset: OPL3 Proprietary
Onboard Mixer: Yes
Midi Land
Model: MidiWin
Warranty: 1 Yr.
DSP Included: Yes
MIDI Interface Included: Opt.
Onboard Mixer: Yes
Multiwave Innovation
Model: Audiowave Platinum 16
Phone: (408) 379-2900
Warranty: 1 Yr.
DSP Included: No
Onboard Mixer: Yes
New Media Corporation
Model: .Wavjammer
Phone: (714) 453-0100
Warranty: Life
Computer Interface: PCMCIA
DMA Channels Above 3 Supported: N/A
DSP Included: No
Onboard Mixer: Yes
CD-ROM Interface:
Omni Labs
Model: Audio Master
Phone: (415) 788-1345
Warranty: 1 Yr.
DSP Included: Yes
Adlib Compatible: Opt
Sound Blaster Compatible Via: Optional FM Chip
Onboard Mixer: Opt
CD-ROM Interface: Optional SCSI w/ASPI
Orchid Technology
Model: GameWave 32
Phone: (510) 683-0300
Warranty: 4 Yr.
Max Sample Rate-Recording in kHz: N/A
DSP Included: Yes
Synthesizer Chipset: Analog Dec. DSP
Onboard Mixer: No
Orchid Technology
Model: SoundWave 32
Warranty: 4 Yr.
DSP Included: Yes
Onboard Mixer: Yes
Reveal Computer Products
Model: SC600
Phone: (800) 473-8325
Warranty: 1 Yr.
DSP Included: No
Onboard Mixer: Yes
Roland
Model: RAP-10/A+
Phone: (213) 685-5141
Warranty: 1 Yr.
DSP Included: Yes
Synthesizer Chipset: Roland Sound Canvas
Onboard Mixer: Yes
CD-ROM Interface:
Sigma Designs
Model: WinSound 16
Phone: (510) 770-0100
Warranty: 5 Yr.
DSP Included: No
Onboard Mixer: Yes
Sound Minds Technology
Model: ITL1600
Phone: (408) 374-7070
Warranty: 1 Yr.
DSP Included: No
Onboard Mixer: Yes
Toptek Technology
Model: Golden Sound Pro 16
Phone: (818) 960-9211
Warranty: 1 Yr.
DSP Included: Yes
Onboard Mixer: Yes
Toptek Technology
Model: Golden Sound Pro 16 Plus
Warranty: 1 Yr.
DSP Included: Yes
Onboard Mixer: Yes
Turtle Beach Systems
Model: Multisound Monterey
Phone: (914) 966-0600
Warranty: 1 Yr.
DSP Included: Yes
Synthesizer Chipset: TurtleBeach/ICS
Sound Blaster Compatible Via: None
Via MPU-401 Emulation: UART windows only
Onboard Mixer: Yes
CD-ROM Interface:
Vision Enhancements
Model: Vision Sound Solution
Phone: (602) 265-5665
Warranty: 3 Yr.
DSP Included: Yes
Synthesizer Chipset: Oak Mozart
Onboard Mixer: Yes
Wearnes Technology
Model: Beethoven ADSP-16
Phone: (408) 456-8838
Warranty: 1 Yr.
DSP Included: Yes
Synthesizer Chipset: ADI
Onboard Mixer: Yes
Reply 167 of 247, by FreddyV
seob wrote on 2018-03-29, 12:49:
Motiveren you didn’t have a picture of the Logitech soundmachine wave in the Google docs. So here it is.
My Logitech SoundMan Wave Pircture is better 😀
I also have 3 Turtle beach tropez (One complete in box) and others not common I don't remember
    1.68 MiB
Reply 168 of 247, by cyclone3d
Sheesh. I should use my big scanner to take high-res pics of the cards I have.
No reflections or out of focus areas, just sweet, sweet, high resolution pics from the scanner. Only thing is it takes forever to do a single scan.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 169 of 247, by bristlehog
Added 19 different OKSORI soundcards with pictures from this blog post seemingly by a Korean collector.
Reply 170 of 247, by derSammler
What about this one? IBM M-ACPA Adapter (made by Tecmar). According to this, it seems to have outstanding audio quality. Though I have the ISA variant, but the chips on it are the same.
Looks like it has some value. 😉
Reply 171 of 247, by bristlehog
derSammler wrote on 2020-01-19, 14:57:
It's already on the spreadsheet under the name of 'Tecmar M-ACPA (for IBM) rev. B (assy rev. D)'. I added you to the list of card owners. Do tell, what FCC ID does your card have?
To me it looks like wiredforservice fallaciously thinks every obscure 8-bit sound card matches the value of Adlib Gold 😉
Reply 172 of 247, by cyclone3d
That card has been on eBay for many months.
YMF7x4 Guide
Reply 173 of 247, by derSammler
bristlehog wrote on 2020-01-19, 16:53:
I'll let you know next time I take the card out of storage. Just did a quick picture yesterday before putting the card into storage, since I have no rig for testing sound cards currently.
Reply 174 of 247, by daikatana_
kanecvr wrote on 2017-01-04, 23:13:
I don't know how rare early Sound blaster clone cards are, but here she is: […]
It's an Anchor Electronics Media Concept 2.0 (SB clone). As far as I can tell it uses a few parts found on the creative SB 1.0, some off the 2.0 and some custom parts. I tested it with the creative sb driver and it works, but doesn't sound quite right in some games. After tracking down and installing the correct driver for this card, all issues went away - and it sounds lovely. Then again the original driver only adds the SET BLASTER and SET MC arguments to autoexec. The big 74xxxx chip seems to be a regular OPL that has been re-etched, same for some of the other chips. The 3 empty sockets will take CMS chips off a genuine sound blaster. The only custom chip as far as I can tell is the MS1006.
With it's own drivers installed it has great output - no noise, no distortion and the OPL sounds genuine (at least to me). The card is made in 1992.
Games tested: Monkey island, Lemmings, Prince of Persia, Keen 2, Keen 4 and Supaplex.
P.S. - got it from a fellow vogons member.
Do you still have original drivers for the card, by any chance? I just got the card but can't find the drivers anywhere on the net.
Cheers
Game MIDI soundtracks
Retro games and HW reviews
Reply 175 of 247, by cyclone3d
daikatana_ wrote on 2020-01-29, 21:47:
Cheers
Haha... found them.
http://files.mpoli.fi/hardware/SOUND/OTHER/
LD_MEDC2.ZIP
1.65 MiB
54 downloads
Here is another set.. maybe the same?
http://vogonsdrivers.com/getfile.php?fileid=821&menustate=0
And more:
ftp://148.6.76.109/Drivers/Sound/creative/SBL … STER.20/SB20MC/
YMF7x4 Guide
Reply 176 of 247, by daikatana_
cyclone3d wrote on 2020-01-30, 01:17:
Haha... found them. http://files.mpoli.fi/hardware/SOUND/OTHER/ LD_MEDC2.ZIP […]
Cheers
Haha... found them.
LD_MEDC2.ZIP
And more:
Thanks, I'll try these. I was looking for drivers for Anchor sound card.
Reply 177 of 247, by cyclone3d
daikatana_ wrote on 2020-01-31, 13:39:
Cheers
Haha... found them.
LD_MEDC2.ZIP
And more:
Back in the day a lot of cards were sold under various brands even though they were the same exact card or used the same exact driver.
From what I could tell, any of those 3 that I posted/linked to should work.
YMF7x4 Guide
Reply 178 of 247, by daikatana_
cyclone3d wrote on 2020-01-31, 17:11:
Haha... found them.
LD_MEDC2.ZIP
And more:
Does it work like that with Gravis Ultrasound and its clones as well?
Reply 179 of 247, by hard1k
Exactly. Vast majority of them being produced by Synergy, including the "original" GUS PnP itself.
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
