Rarest CPUs?
Reply 160 of 442, by hyoenmadan
dionb wrote on 2020-12-29, 00:31:
Itanium's problem is that there are simply very few people out there interested in them, not anything intrinsic in their performance or compatibility.
Also, generally Itanics, like many highend stuff, goes almost directly to the scrap factory via e-recycle contracts and stuff. As you already know, in many countries is illegal to get anything from these centers. Nekochan guys have been able to save some of that stuff with some luck, contacts and black magic, but even they can't save all it.
Reply 161 of 442, by Caluser2000
debs3759 wrote on 2020-12-26, 21:35:
Repo Man11 wrote on 2020-12-26, 16:31:
386SX wrote on 2020-12-26, 13:32:
I think there're nowdays even more shades of "rare" definitions considering even most common ones are "rare" too. For example cpu like the Athlon 1000 on Slot is not that easy to find or the K62+@570 and the K63+@550 actually I've never seen these and I doubt I'll ever see them. Only found a K63-400@2,4v and a K62+@550 that already are not that common in the middle of most K6-2@400 or 450Mhz.
I found a 486 Overdrive DX4 100Mhz with write-through cache in a computer fair years ago. It's still nice to have with the heatsink and the voltage regulator already on the top of the cpu even if using it without a fan on it is almost scary.. heatsink temperatures goes up incredibly high.
I just saw a K6-III+ 550 on Ebay sell for $460.00! I wonder if the buyer will actually put it in a motherboard and fire it up?
We tried a group buy for 50 of them on CPU-World. A member saw it and outbid us, then set up a new eBay account to sell them. I advise against buying off that seller until lack of interest pushes the price down.
Why|? Your lose, his gain. That's how biding works.
Reply 162 of 442, by Anonymous Coward
rmay635703 wrote on 2020-12-28, 22:02:
From what I can tell anything Intel 808X-6 is very old made before 1982 and 6mhz […]
Anonymous Coward wrote on 2020-12-28, 10:46:
Does anyone have a datasheet for 8086/87 before intel started using the -1,-2, -3 naming scheme?
Many years ago I owned an IBM branded 8087-6. It outperformed the 8087-3 at the same clock speed in both synthetic and real world tests (both were tested in IBM 5160 at 4.77MHz). I could never find a datasheet that mentioned the -6.
If you can let me know what age the piece of equipment was the 8087-6/8088-6 came out of?
My 5150 with an 8088-6 is a very early 64k model
The 8086-6 I received from the legendary Jack Allen computers bought for pennies soldered to a piece of s100 board scrap. At the time he would let me scrounge through the scrapped boards, got a real ibm ega card from there.
I was a kid at the time and when the 1980 dated board didn’t sell on eBay for $5, I scrapped it again in 1999. I never figured an 8086-6 was of any historical significance, just a failed attempt by Intel to sell a faster speed grade than the 4/5 MHz chips they otherwise were hocking.
In terms of an IBM Branded 808X being faster it doesn’t surprise me, IBM had the rights to Intels designs through the 286 and likely overbuilt them in typical IBM fashion
Ah well
I am pretty sure I bought my 8087-6 from a computer surplus in the 90s. I asked the shop owner if they had any 8087s, and they pulled out a tray with a bunch of loose chips rattling around. As it had IBM stamped onto it, it's probably pretty safe to assume they pulled it from one of the many 5150s or 5160s on their shelves. I recall, they had quite a few 64k 5150s, because they had the two screw covers and black power supplies (I had to really dig to find a 640k XT).
According to CPU-World, IBM did not make 8087s for Intel. They just stamped 'IBM' into the Intel chips and sold them in their kits.
Reply 163 of 442, by Living
i have a Ceramic Pentium MMX 233Mhz, brown like the non MMX Pentium, is it rare? is the only 233 i seen like this
https://www.engineering-sample.com/gallery/In … 233%20MHz%20QS/
Reply 165 of 442, by debs3759
Living wrote on 2020-12-30, 09:35:
Definitely fake. Genuine MMX 233 are plastic/fibre. All genuine Q140 are the same as the retail chips.
Reply 167 of 442, by Anonymous Coward
It's still cool though, because it's an unlocked 166MMX.
Reply 168 of 442, by debs3759
Anonymous Coward wrote on 2020-12-30, 12:35:
And will overheat due to the layer of paint, if that is not cleaned off. Might not even be a 166, the sSpec and part number don't match, so it may not even be an MMX (unless it has been tested as one)
Reply 170 of 442, by pentiumspeed
The surface has several chipped spots that's overlaid over original surface and remarked. Fake.
I have one was 120MHz but remarked for 133MHz, fake.
Cheers,
Great Northern aka Canada.
Reply 171 of 442, by thehinac
I have a nexgen P133-D/J now. That's pretty rare. still looking for the silk screened 110 & 120 though, only 2 I still need. I'd pay good money for them, but I think a 120 popped up on ebay like one time in the past like 10 years, but all the pins were bent on it. I've gotten no leads since then. I found one collector but they wouldn't part with it. Who would right?
Reply 173 of 442, by vmr_
mt777 wrote on 2021-07-04, 00:50:
I have P120 but doesn't boot 😒
What was purpose of these cpus (120/133)? NxVL has jumpers for max P110?
I think only the PCI version of Alaris Nexgen mobo supports P120. I can test it for you 😀
Retro builds & sandbox
IBM XT 5160 | 286 | 386 | 486 | S4 SI5PI AIO & S4 Batman + P60 SX828
S8 & PPro 200 | SS7 FW 5VGF & Asus P5A & AOpen AX59PRO K6-III+ 550MHz
Asus K7M Athlon 1Ghz GDF | Abit SH6 Pentium III 1GHz SL4KL...
Reply 175 of 442, by Caluser2000
I have this one. The smaller lower writing on the top is laser etch on. Not painted.
    605.33 KiB
    590.74 KiB
Reply 176 of 442, by BitWrangler
I have a ceramic 166MMX also, no glamour shot as it's larded up with white thermal paste still. Think they were common as a 166 though.
Reply 177 of 442, by Caluser2000
BitWrangler wrote on 2021-08-03, 18:41:
I've got gizillions of the later 166s and 200s. They swarm like wasps...
Reply 178 of 442, by cyclone3d
I ran across an IDT Winchip C6 240Mhz and it is on the way now. The 200 and 225Mhz seem not that rare, but I hadn't run across the 240 before ,and from what I could find, very few were supposed to have ever been sold.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 179 of 442, by debs3759
cyclone3d wrote on 2021-12-10, 01:30:
I've had one for a few years, pretty sure I've seen a few on CPU-World. They're definitely not common though
