Reply 160 of 384, by markanini
Falcosoft wrote on 2024-04-15, 16:34:1. It's enough the send a GM or GS Reset SysEx to cure pitch issue. If you use FSMP or Van Baso you can set them to send resets […]
markanini wrote on 2024-04-15, 14:39:Can anyone guide on how to handle the two main quirks of mkII rom? If I'm not wrong one is related to battery detection causing pitch change, the second one is missing sounds cased by sound mapping discrepancies aka capital tone fallback.
I've seen seen GS reset proposed as a solution for both issue: Q, hold U and press Q, W.The question is when is a good time to use the reset operation?
1. It's enough the send a GM or GS Reset SysEx to cure pitch issue. If you use FSMP or Van Baso you can set them to send resets every time a new title is played.
2. Key combo reset and GS reset cannot cure capital tone fallback related problems.
2a. To cure capital tone fallback related problems the simplest way is to send a GM reset. This way all bank select messages are ignored by mkII. But this way you actually disable all variation tones.
2b. The more sophisicated method that does not disable all variation tones is to use FSMP and its software Capital Tone Fallback feature:
You should click Main menu -> Instruments -> Custom Patch definitions and select Roland SCVA -> 'Roland SCVA-55' for melodic and 'Roland SCVA-55 Drumsets' for drum channels. Then you should also enable 'Use Patch info for Capital Tone Fallback' option.
I guess the 2a is the best option dealing with game midi then, when needed. Until someone modifies the rom to handle the issue differently. Thanks for the advice.
EDIT: For reference GM reset is done by: Q. Hold T, press W
